1912 coil box
Colin Mavins
First Name: Colin
Last Name: Mavins
1912 coil box
Post by Colin Mavins » Mon Jul 01, 2024 3:51 pm
I just bought the coil box for the 1912 from market place which was brought to light in the classified ads When I looked it up it was marked 250 dollars so I snapped it up it is missing the nuts that hold the coils in, can anyone post a picture of what they look like. Thanks Colin
Re: 1912 coil box
Post by RajoRacer » Mon Jul 01, 2024 4:10 pm
What maker of coil box ?
Colin Mavins
First Name: Colin
Last Name: Mavins
Re: 1912 coil box
Post by Colin Mavins » Mon Jul 01, 2024 4:21 pm
This is what I bought 250 dollars Would the missing nuts be the same nuts from the engine side of the box I currently have a reproduction box from 1961 which is made bigger for newer coils the 1910 box has the brass side attachment brackets. I may not change it now but it is nice to have the correct box ready to go , I have the original 1910 box but no lid it came with the car in 1960 the car had a 1915 box installed in it. The last pic is my car now.
Colin Mavins
First Name: Colin
Last Name: Mavins
Re: 1912 coil box
Post by Colin Mavins » Mon Jul 01, 2024 4:22 pm
It is a kingston box coils and switch
RGould1910
Last Name: Gould
Re: 1912 coil box
Post by RGould1910 » Mon Jul 01, 2024 4:41 pm
Here you go. The nuts look to be the size of spark plug nuts smaller and clearly different fron the terminal nuts on the engine side. :)
Colin Mavins
First Name: Colin
Last Name: Mavins
Re: 1912 coil box
Post by Colin Mavins » Mon Jul 01, 2024 4:49 pm
They look very much like whats on the nos X plugs from the 1920s
RGould1910
Last Name: Gould
Re: 1912 coil box
Post by RGould1910 » Mon Jul 01, 2024 5:08 pm
Yep, that they do!
Colin Mavins
First Name: Colin
Last Name: Mavins
Re: 1912 coil box
Post by Colin Mavins » Mon Jul 01, 2024 9:35 pm
Thank You that solves the question I should have it here in 5 days your post is a lot better than here in Canada, I have some old plugs but the top nut is much smaller but my nos plugs from way back the nut is much larger. I guess I'm going to learn about these coils this will be my first, I know Dad never had coils so went with what he had and it has worked for 60 years. I other question what is the wire for? Cheers Colin
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: 1912 coil box
Post by ThreePedalTapDancer » Tue Jul 02, 2024 4:43 pm
The red wire is to bypass the coils because a master vibrator was hooked up instead. The contacts on each of the four coils were bypassed, and a single contact in the master vibrator takes over the function of the four coils.
