Bent Rods
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Bent Rods
Post by Dave Young » Mon Sep 09, 2024 9:43 pm
Does anyone know if Kohnke Rebabbitting is still in operation? I’m suspecting that I have a few bent rods in a newly done engine and would like to have them all checked. Herm had done excellent work for me in the past and I do know that his son was continuing the business after his passing, but haven’t had any luck reaching him. Also, who else is reputable for rod straightening nowadays?
Junk poor
First Name: D
Last Name: Brown
Re: Bent Rods
Post by Junk poor » Mon Sep 09, 2024 10:09 pm
J and M Machine
Last Name: Gulbankian
Re: Bent Rods
Post by J and M Machine » Tue Sep 10, 2024 8:35 am
Yes he in business and his name is John
Dave Young
First Name: David
Last Name: Young
Re: Bent Rods
Post by Dave Young » Tue Sep 10, 2024 2:01 pm
Thanks guys. John sent me his cell number.
Kerry
Last Name: van Ekeren
Re: Bent Rods
Post by Kerry » Tue Sep 10, 2024 6:09 pm
It's not rocket science to make your own mandrel to check them, they can even be realigned in a good 6" bench vice.
Re: Bent Rods
Post by speedytinc » Tue Sep 10, 2024 6:26 pm
Dave, since you are sharp enough to be concerned about bent rods, you know how to avoid bending them during piston installation & removal.
I will say, I check every rebabbited rod I get before installing. Around 1/2 from suppliers are out of square/bent.
I have found bent rods in fresh rebuild motors that I had to go thru to correct builders errors.
Trust but verify.
Re: Bent Rods
Post by RajoRacer » Tue Sep 10, 2024 6:45 pm
I agree with John, even though you pay "good money" for re-Babbitted con. rods, one should verify that they are straight !
Stevens & KR Wilson both made superior tools for checking rods - I also have a flywheel attachment for setting magnet heights for my Stevens.
Re: Bent Rods
Post by speedytinc » Tue Sep 10, 2024 6:52 pm
Luvin' the flywheel attachment.
I got some building to do.
Re: Bent Rods
Post by RajoRacer » Tue Sep 10, 2024 9:41 pm
I took the idea from the Ford Service Manual !
Re: Bent Rods
Post by Allan » Wed Sep 11, 2024 3:36 am
This is my Ausrtalian made set up for rod aligning.
Instead of multiple round mandrels to take multiple sized rods, it comes with just 3 machined square mandrels. These can take rods as small as T up to large diesel truck rods. My local machine shop never had a use for their small one, so it was given to me.
10 years later my cousin found the matching precision vice used to straighten rods.
Dave Young
First Name: David
Last Name: Young
Re: Bent Rods
Post by Dave Young » Wed Sep 11, 2024 7:58 am
I’d sure like to find one of these fixtures
Re: Bent Rods
Post by speedytinc » Wed Sep 11, 2024 8:12 am
The fixtures show up @ swap meets occasionally but, the seals are rarely with them & a hard find.
Simple, functional substitutes can be made from about a 4" notched square plate.
