Clutch Basket puller advice please
Rata Road
First Name: Kevin
Last Name: Weeds
* REQUIRED* Type and Year of Model Ts owned: 1923 Depot Hack, 1927 Coupe & 1914 Runabout
Post by Rata Road » Mon Sep 16, 2024 5:24 pm
I'm about to venture into my first T Transmission and after watching a few videos I don't think I have the appropriate puller for removing the Clutch Basket if it is stuck on.
Beside buying a new one from a vendor what other options do I have?
Re: Clutch Basket puller advice please
Post by speedytinc » Mon Sep 16, 2024 5:39 pm
First off, it better be stuck on. It's a press fit part. If it comes off easy, the hub or the shaft is too worn to reuse.
Langs sells a copy of a Stevens type puller for $195
The Ford Z tool is vastly inferior but usually works.
You could, possibly make a workable tool. A Harbor freight steering wheel puller set looks like a good start for about $18.
Harbor freight has a set of 2 arm pullers for around $30.
Best to find a local T friend for the loan of the correct tool.
Post by DanTreace » Mon Sep 16, 2024 5:50 pm
Used with success a heavy gear puller. Was snuggle but off it came.
100_8927 (800x600) (800x600) (2).jpg (118.51 KiB) Viewed 4924 times
Post by speedytinc » Mon Sep 16, 2024 5:55 pm
That looks like one of the HF 3 piece set.
Be real careful the tool don't blow apart under the strain.
Some hubs fit extremely tight.
Post by Steve Jelf » Mon Sep 16, 2024 5:59 pm
Sometimes the original puller can't handle the job. It's been a few years, but I did figure out a method that worked.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Mon Sep 16, 2024 7:14 pm
I repeatedly applied a 50/50 mix of ATF and acetone to a badly rusted transmission that had been in the field for 50+ years. After 2 days, it came apart surprisingly easy.
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Mon Sep 16, 2024 7:18 pm
That's a tease Steve!
More please.
Pleased to see you back up and posting, Wendy and I were worried for some time.
I do have a few pullers, top right is a 6".
I'm going to a swap meet this Saturday so any ideas on what to look out for would be great.
[attachment=1]DSCN5029.JPG[/attachment]
[attachment=0]DSCN5030.JPG[/attachment]
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Mon Sep 16, 2024 7:28 pm
I’ve successfully used an original puller on a non-rusted transmission.
Here’s a 2017 post showing one Mr Jelf has used. http://mtfca.com/discus/messages/708324 ... 1485141493
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Mon Sep 16, 2024 8:06 pm
Thanks K - that gives me some idea.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Mon Sep 16, 2024 8:28 pm
I made a puller from scrap. It's not pretty, but does the job quite well.
The arms on the Ford design has a tendency to bend inward, which could possibly damage the basket.
Art Mirtes
Post by speedytinc » Mon Sep 16, 2024 8:52 pm
Before you re-install the clutch hub, check for roundness.
A tough to pull hub can "taco" out of shape.
Post by Steve Jelf » Mon Sep 16, 2024 10:37 pm
Oh yeah, that's how I did it. Since breaking my fall by hitting the pavement head first, I don't always do well with searches. :D
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Sep 16, 2024 10:57 pm
Hi Kevin,
I used a harmonic balancer puller with two L bolts made from grade 8 x 6" bolts with the heads cut off, heated & bent to a 90 degree angle
about 1/2" long. I now have the Ford puller but have had to make more robust pins for it & straighten it once after a especially had hub pull.
Has anyone considered drilling & tapping the main shaft so a stud could be installed & used to push the clutch basket back on the shaft
instead driving it on against the thrust bearing??
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Tue Sep 17, 2024 5:58 am
I use this puller , and works good .
Toon
Post by Allan » Tue Sep 17, 2024 6:50 am
Mine's a bit like yours Toon. It has two hooks to engage in the clutch hub. The cross piece is a bit of heavy wall retangular hollow section, with a centre bolt to provide the "pull".
Post by John kuehn » Tue Sep 17, 2024 8:43 am
I’m surprised no one has mentioned using a little heat to remove the clutch drum. It works most every time. Heat up the drum at the shaft going through it, let it cool and use WD40 and let sit a while. It usually pulls right off.
Post by speedytinc » Tue Sep 17, 2024 11:01 am
Maybe there's a reason.
These are press fit parts. Anything that changes sizing lessens the fit. That would be bad.
Using fluids to penetrate rust & baked in grease is ok.
Post by John kuehn » Tue Sep 17, 2024 11:43 am
I guess everyone has a different view of how to do it but when I heat the center of the hub I
dont get the hub red hot meaning it doesn’t get that hot. Let it cool it will be Ok.
The hub will press back on as usual and a good tight fit. It works for me.
cwhuntersr
First Name: CW
Last Name: Hunter
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup
Post by cwhuntersr » Tue Sep 17, 2024 12:45 pm
PB Blaster the night before, then use a gear puller, some heat, and tapping around the basket with a hammer. Careful though, once it lets loose the gear puller might fly off
Post by Original Smith » Tue Sep 17, 2024 1:00 pm
Try reading the Ford Service book!
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Wed Sep 18, 2024 4:29 am
Lots of good ideas guys,
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Wed Sep 18, 2024 4:33 am
Toon - That looks a simple build, What's the distance between the 2 holes in the plate?
Ta
ABoer
Last Name: Boer
Post by ABoer » Wed Sep 18, 2024 12:01 pm
Kevin W .
The plate is : 125 x 50 x 12 mm
The holes are 13 mm , and centre to centre 82 mm .
And the two small plates are : 40 x 25 x 6 mm with a 10 mm hole .
I hope this helps you .
Toon
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Wed Sep 18, 2024 4:20 pm
Got it,
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Sat Sep 21, 2024 4:47 am
Couldn't find a suitable puller but I bought this today at a swap meet.
I'll pull it apart tomorrow and that might confirm if what I have on hand is suitable for the job.
What years is this set up from?
[attachment=0]DSCN5053.JPG[/attachment]
[attachment=1]DSCN5052.JPG[/attachment]
[attachment=2]DSCN5051.JPG[/attachment]
[attachment=3]DSCN5050.JPG[/attachment]
[attachment=4]DSCN5049.JPG[/attachment]
