flush
Topic author - Posts: 329
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
flush
Over the years I think I've probably tried all the available radiator flushes. Even CLR, but now the instructions on CLR say not for cooling systems. What is the best one for a Model T?
Re: flush
Many of us have had excellent results from Coca-cola.
Flush with clean water & add 1 or 2 cans of coke. Run a few hours & look in the radiator. When you see nice clean brass, your done.
Flush & add fresh water & some water soluble oil or your preferred coolant.
Coke has phosphoric acid (metal prep). It will make a steak disappear, i am told.
Re: flush
I use Evapo-Rust Thermocure - check it out - good stuff.
- First Name: Rich
- Last Name: Bingham
Re: flush
Is a slightly less than a 7% solution of Coca Cola really effective ? (3.5% if you only use one 12 oz can)
Asking for a friend . . .
Get a horse !
- First Name: Tom
- Last Name: Moorehead
Re: flush
As far as the steak goes, I know for a fact that coke will actual dissolve a steak after about 24 hours. Someone told me that and I tried a small raw pice of steak in coke. Nothing but a gummy mess. An old plumber friend uses coke soaked rags overnight to eat away deposits to get a pipe fitting to turn! Wonder what it does to the stomach?
Re: flush
The stomach contains Hydrochloric acid. Don't think Coke would even come close to that!Tmooreheadf wrote: ↑Sat Sep 07, 2024 9:27 pmAs far as the steak goes, I know for a fact that coke will actual dissolve a steak after about 24 hours. Someone told me that and I tried a small raw pice of steak in coke. Nothing but a gummy mess. An old plumber friend uses coke soaked rags overnight to eat away deposits to get a pipe fitting to turn! Wonder what it does to the stomach?
- First Name: Vernon
- Last Name: Worley
Re: flush
Last week I finished flushing out the radiator, on a different car, 3x with bluedevil from AZ. The overheating stopped, had lots of mud.
In the past I've used vinegar.
After either one, I drain and empty into the septic system, flush with a garden hose with the engine running. Engine off, drain cock on radiator and block open until empty. Then distilled and green stuff.
Vern (Vieux Carre)
- First Name: Thomas
- Last Name: Loftfield
Re: flush
Vinegar 50/50 with water. Dissolves corrosion without touching good metal. Excellent for all metal cleaning. Cheap!
- First Name: Herb
- Last Name: Iffrig
Re: flush
What type of vinegar?
- First Name: Rich
Re: flush
Grocery store “white vinegar” is cheapest, and in actuality is no more than a solution of acetic acid and distilled water. Works fine for the purpose. “Real” vinegar from apple cider, or rice wine is for salads and the kitchen, and costs much more.
Last edited by Rich P. Bingham on Sun Sep 08, 2024 3:01 pm, edited 1 time in total.
Get a horse !
Re: flush
While not as cheap as store bought white vinegar, I just saw at one of the national hardware chains (Lowes I think), a stronger vinegar. Don't recall what the strength was. Did a quick search, looks like many places have it, look for cleaning vinegar. If you use it or any acid to strip rust would suggest using baking soda to neutralize after cleaning.
Re: flush
I don't know that answer to that Tom, but I can tell you what my stomach does to a steak!Tmooreheadf wrote: ↑Sat Sep 07, 2024 9:27 pmAs far as the steak goes, I know for a fact that coke will actual dissolve a steak after about 24 hours. Someone told me that and I tried a small raw pice of steak in coke. Nothing but a gummy mess. An old plumber friend uses coke soaked rags overnight to eat away deposits to get a pipe fitting to turn! Wonder what it does to the stomach?
Re: flush
I wonder if that's due to modern cooling systems using aluminum? (Like a Z head maybe?)
Re: flush
Sounds about right, didn't look that close but recall the number was double digit.
- First Name: Doug
- Last Name: Wilson
Re: flush
Have been thinking of doing the vinegar radiator cleaning. From those who have had success with this, what concentration in the radiator is used and how long should the engine be run for a vinegar flush?
I believe 5% concentration (household) vinegar would be sufficient as have had success cleaning small parts with that, although it does take a day or two. The previous owner rebuilt the engine a few years before I bought it (so far it seems whoever he had do the engine did a good job). The block water passages looked clean when I replaced the radiator hoses. The radiator is not too good, but think flushing would be worth a try. The coolent gets pretty muddy/rusty after a run, but settles out clear in time.
It would seem that a neutralizing rinse with a bit of baking soda added followed by a clean water rinse would also be a good idea.
