flush
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
flush
Post by thom » Sat Sep 07, 2024 6:48 pm
Over the years I think I've probably tried all the available radiator flushes. Even CLR, but now the instructions on CLR say not for cooling systems. What is the best one for a Model T?
Re: flush
Post by speedytinc » Sat Sep 07, 2024 7:31 pm
Many of us have had excellent results from Coca-cola.
Flush with clean water & add 1 or 2 cans of coke. Run a few hours & look in the radiator. When you see nice clean brass, your done.
Flush & add fresh water & some water soluble oil or your preferred coolant.
Coke has phosphoric acid (metal prep). It will make a steak disappear, i am told.
Re: flush
Post by RajoRacer » Sat Sep 07, 2024 8:29 pm
I use Evapo-Rust Thermocure - check it out - good stuff.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: flush
Post by Rich P. Bingham » Sat Sep 07, 2024 8:44 pm
Is a slightly less than a 7% solution of Coca Cola really effective ? (3.5% if you only use one 12 oz can)
Asking for a friend . . . ;)
Get a horse !
Tmooreheadf
Last Name: Moorehead
Re: flush
Post by Tmooreheadf » Sat Sep 07, 2024 9:27 pm
As far as the steak goes, I know for a fact that coke will actual dissolve a steak after about 24 hours. Someone told me that and I tried a small raw pice of steak in coke. Nothing but a gummy mess. An old plumber friend uses coke soaked rags overnight to eat away deposits to get a pipe fitting to turn! Wonder what it does to the stomach?
Re: flush
Post by Mark Gregush » Sat Sep 07, 2024 9:42 pm
The stomach contains Hydrochloric acid. Don't think Coke would even come close to that! :lol:
varmint
First Name: Vernon
Last Name: Worley
Re: flush
Post by varmint » Sat Sep 07, 2024 9:56 pm
Last week I finished flushing out the radiator, on a different car, 3x with bluedevil from AZ. The overheating stopped, had lots of mud.
In the past I've used vinegar.
After either one, I drain and empty into the septic system, flush with a garden hose with the engine running. Engine off, drain cock on radiator and block open until empty. Then distilled and green stuff.
Vern (Vieux Carre)
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Re: flush
Post by Loftfield » Sun Sep 08, 2024 7:29 am
Vinegar 50/50 with water. Dissolves corrosion without touching good metal. Excellent for all metal cleaning. Cheap!
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: flush
Post by Herb Iffrig » Sun Sep 08, 2024 11:49 am
What type of vinegar?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: flush
Post by Rich P. Bingham » Sun Sep 08, 2024 12:24 pm
Grocery store “white vinegar” is cheapest, and in actuality is no more than a solution of acetic acid and distilled water. Works fine for the purpose. “Real” vinegar from apple cider, or rice wine is for salads and the kitchen, and costs much more.
Last edited by Rich P. Bingham on Sun Sep 08, 2024 3:01 pm, edited 1 time in total.
Get a horse !
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Re: flush
Post by Ed Fuller » Sun Sep 08, 2024 2:11 pm
I agree with Steve. Thermocure by Evaporust works great and doesn’t make you stink like vinegar!
Re: flush
Post by Mark Gregush » Tue Sep 17, 2024 1:01 pm
While not as cheap as store bought white vinegar, I just saw at one of the national hardware chains (Lowes I think), a stronger vinegar. Don't recall what the strength was. Did a quick search, looks like many places have it, look for cleaning vinegar. If you use it or any acid to strip rust would suggest using baking soda to neutralize after cleaning.
Mark Nunn
Last Name: Nunn
Re: flush
Post by Mark Nunn » Tue Sep 17, 2024 2:22 pm
Mark, that cleaning vinegar that I have is 30%. Household vinegar is 5%.
Re: flush
Post by Jerry VanOoteghem » Tue Sep 17, 2024 2:55 pm
I don't know that answer to that Tom, but I can tell you what my stomach does to a steak!
Re: flush
Post by Jerry VanOoteghem » Tue Sep 17, 2024 2:57 pm
I wonder if that's due to modern cooling systems using aluminum? (Like a Z head maybe?)
Re: flush
Post by Mark Gregush » Tue Sep 17, 2024 4:00 pm
Sounds about right, didn't look that close but recall the number was double digit. :)
Phoenix88R
First Name: Doug
Last Name: Wilson
Re: flush
Post by Phoenix88R » Sat Sep 21, 2024 1:35 pm
Have been thinking of doing the vinegar radiator cleaning. From those who have had success with this, what concentration in the radiator is used and how long should the engine be run for a vinegar flush?
I believe 5% concentration (household) vinegar would be sufficient as have had success cleaning small parts with that, although it does take a day or two. The previous owner rebuilt the engine a few years before I bought it (so far it seems whoever he had do the engine did a good job). The block water passages looked clean when I replaced the radiator hoses. The radiator is not too good, but think flushing would be worth a try. The coolent gets pretty muddy/rusty after a run, but settles out clear in time.
It would seem that a neutralizing rinse with a bit of baking soda added followed by a clean water rinse would also be a good idea.
Ed Fuller
First Name: Ed
Last Name: Fuller
Re: flush
Post by Ed Fuller » Sat Sep 21, 2024 1:55 pm
Just buy a jug of Thermocure. No guesswork involved. It was designed to do the job, just follow the directions.
