accessory switch and amp meter
dang.1922
Topic author - Posts: 57
- Last Name: Greger
Has anybody seen an accessory amp meter and switch like this that mounted onthe steering colum?g
Re: accessory switch and amp meter
I have not seen one. It looks as if it was a solution, searching for a problem.
It would be interesting to see what's inside the box. The two side pull/push knobs on the right suggest a turn signal setup & the the push button on the left may be for a horn. Using both turn signals & its an emergency flasher
The 2 switches on the right could be for high/low beams.
