accessory switch and amp meter
dang.1922
Last Name: Greger
Post by dang.1922 » Wed Sep 18, 2024 11:19 am
Has anybody seen an accessory amp meter and switch like this that mounted onthe steering colum?g
Re: accessory switch and amp meter
Post by Jerry VanOoteghem » Wed Sep 18, 2024 11:26 am
I have not seen one. It looks as if it was a solution, searching for a problem. :)
Post by TRDxB2 » Wed Sep 18, 2024 12:32 pm
Has anybody seen an accessory amp meter and switch like this that mounted onthe steering colum?gIMG_2269.jpegIMG_2267.jpegIMG_2270.jpeg
It would be interesting to see what's inside the box. The two side pull/push knobs on the right suggest a turn signal setup & the the push button on the left may be for a horn. Using both turn signals & its an emergency flasher :roll:
Post by Mark Gregush » Thu Sep 19, 2024 11:17 am
The 2 switches on the right could be for high/low beams.
