Timing Gear Nut Dimensions Needed
Post by Jerry VanOoteghem » Tue Dec 17, 2024 8:56 am
Can someone please give me the dimensions of the timing gear nut? I'm only needing the dimension across the flats and the outside diameter of the flange.
Thanks!!
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Timing Gear Nut Dimensions Needed
Post by t-time » Tue Dec 17, 2024 10:50 am
Snyder's repro cam gear nut = 1.130 across flats, 1.375 flange OD
Post by Jerry VanOoteghem » Tue Dec 17, 2024 12:04 pm
Thanks very much. Exactly what I needed!
