Can someone please give me the dimensions of the timing gear nut? I'm only needing the dimension across the flats and the outside diameter of the flange.
Thanks!!
Timing Gear Nut Dimensions Needed
Topic author - Posts: 4237
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Timing Gear Nut Dimensions Needed
Snyder's repro cam gear nut = 1.130 across flats, 1.375 flange OD
