Does this style of luggage rack fold?
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Feb 11, 2025 7:41 pm
Does this style of luggage drag fold, if so how? Thanks.
Adam
First Name: Adam
Last Name: Doleshal
Re: Does this style of luggage rack fold?
Post by Adam » Tue Feb 11, 2025 7:43 pm
Yes. It folds flush to the edge of the running board so you don’t have to remove it.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Feb 11, 2025 8:04 pm
If either end of the diagonal brace has a latch/release, then you can fold it.
Refer to this thread:
https://www.mtfca.com/discus/messages/5 ... 1448354833
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Feb 11, 2025 8:36 pm
I looked at that thread and noticed that the style they mentioned had a cut out latch on the Triangular side. This style does not have such a latch. I wonder if it is homemade?
It looks to me that it is completely riveted together.
Post by John kuehn » Tue Feb 11, 2025 8:43 pm
Use some WD40 or a little oil to lubricate all the joints. Carefully use pressure and it will fold up. Move back and forth a few rimes and it’s OK.
Post by Allan » Tue Feb 11, 2025 10:49 pm
Austin, one end of the diagonal must detach if the thing is to fold. Perhaps in its past the detachable end has been fixed permanently in position. Check that all the rivets are consistent, looking for some difference in one at the diagonal strut end.
A simple way to bring it back into operation is to add a bolt and wingnut in place of a rivet.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Feb 12, 2025 12:59 am
The fact that each of the braces are rounded have rounded instead of square ends is most likely an indication that it folds.
Also, did you check if to see if the end of the diagonal brace that is covered by the vertical brace is slotted so you can push the diagonal brace forward or backward so it no longer rests on the pin/rivet?
Post by Allan » Wed Feb 12, 2025 1:30 am
Another indication that is meant to fold may be the presence of washers between each component of the rack. This is done so they do not bind/scratch on each other as they fold.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Wed Feb 12, 2025 10:34 am
I have one of these and yes it folds down and will be flush with the running board .
Post by TRDxB2 » Wed Feb 12, 2025 12:50 pm
Zooming in it appears that there is one pin position that may provide a disconnect from the angle brace. It may be rusted, see if it will pop out.
The fact that the lower rivets for the uprights are on the inside of the horizontal piece and the rivets on the upper horizontal piece would allow for a flush fold down to the floor board. If they were both on the same side the upper horizontal piece would rest on the lower one when it was collapsed, not flush as others described
Close up rivet.png (295.01 KiB) Viewed 2082 times
Post by Steve Jelf » Wed Feb 12, 2025 3:10 pm
If the diagonal brace can be disconnected, yes.
If it can't, no.
Last Name: House
Post by George House » Wed Feb 12, 2025 4:32 pm
I’m going to say it will fold down once lubricated. Altho slightly different, mine folds down…
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Wed Feb 12, 2025 6:15 pm
Thank you all for your help and ideas I looked at it closer and found that one of the rivets indeed has a larger head and a cut out on the angled bracket, I popped that off with a ball peen hammer and it folds right up now! :)
Now why didn't I notice this before when I was sandblasting it... :roll:
