A few questions about 12 Touring Top
Topic author - Posts: 82
- First Name: Bill
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
I am in the process of having a new top built and installed. I have tuned up the top irons and fitted new bows. I have a friend that has done 2 tops for my brass Buicks but he has never sewn up a T top. I would like to be reasonably accurate on stitching details for the new Touring top. I decided against the top kit route and purchased the necessary fabric for the new top. I would like to be as correct as I can with the top details.
Can someone with a 12 Touring top that you believe to be accurate take the following measurements for me:
1. What is the cross body width for the front to back sewn seams that is the wide center top Fabric (about 40 inches?)
EDIT: IS THE WIDE CENTER TOP FABRIC THE SAME WIDTH FRONT TO BACK?
2. Is the sewn seam on the lower edge of the top (front to back) single stitched or 2 rows of stitching?
3. How many murphy fasteners are on each side of the vertical edge of the roll up rear panel/window? I have seen pictures with just 2 per side including the bottom double Murphy style fasteners or 3 or 4 per side including the double fastener?
Any assistance much appreciated.
Bill
Bill
Re: A few questions about 12 Touring Top
Bill, you may be able to get those details from the makers of the top kits. They will have done it before.
I bought a top kit for my Canadian bodied tourer to tap into their knowledge. Then I had a motor trimmer fit it. I did order it with no fittings in the side curtains so we could put those in just where the body and top irons indicated they should be.
- First Name: Bill
- Last Name: Jones
Allen,
I have thought about making such a contact however it is asking a lot when I did not order a kit from them. Which is why I ask on the forum.
- First Name: Bill
- Last Name: Jones
Bump, Who has a 12 Touring?
- First Name: Stuart
- Last Name: Tomlinson
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
I just measured mine and they are right at 47 inches. Let me know if you need more info.
Stu
Stu
- First Name: Bill
- Last Name: Jones
Stu,
Thanks for replying. Can you provide responses to my #2 and #3 questions in my original post?
Thanks,
Bill
Thanks,
Bill
- First Name: Keith
- Last Name: Townsend
Bill,
I am away from my computer right now, but will be happy to share with you what I can about my late 1911.
I think the tops were the same for '11 and '12.
Keith
Keith
- First Name: Bill
- Last Name: Jones
Keith,
Thanks for responding. I will look for your measurement/answers. Timing is appropriate. I am working with my upholstory/top guy to cover the new bows today.
From reading reports on the forum, those supplying top and upholstery kits have a really good reputation for quality products. Way back in 1990 my Carter's Cut n Cover kits worked a treat on my 1915 tourer. I could see no good reason to re-invent the wheel by starting from scratch with a custom made trim set, and schooling up a trimmer to make same. The time and angst finding all the parameters for the build, and then having a one off top made, was something my trimmer was reluctant to undertake, but he welcomed fitting a ready made kit. At the time it cost me way less due to the time it didn't take to design it form scratch. A big plus was it was made from materials which were not readily available here in Australia at the time.
I would go the same route in a heartbeat if I had a Ford factory car to work on again.
Yes the sewn seem is the same width front to back
- First Name: Keith
Hope these help:
These are the dimensions on my top. Note the vertical bows should be close to the same height.
-Keith
-Keith
I just saw the attachment Keith sent. That nailed it exactly
- Last Name: Hjortnaes
John
Did Vince make diagrams like that for all years?
I have his video on DVD
dave
dave
- Last Name: Tannehill
I can’t say definitely but I have seen 09/10 & a 15 touring. I lost all that several years back when the shop was destroyed along with a table top computer unfortunately.
Best John
Best John
- First Name: Bill
- Last Name: Jones
My thanks to all that responded. Keith Townsend established contact and with his Late 1911 touring has provided great photos and responses to my questions. I am off and running now with my trimmer making the new top. I am new to T's and this forum, what a great forum with helpful folks!
