A few questions about 12 Touring Top
49willard
First Name: Bill
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
Post by 49willard » Mon Feb 24, 2025 5:39 pm
I am in the process of having a new top built and installed. I have tuned up the top irons and fitted new bows. I have a friend that has done 2 tops for my brass Buicks but he has never sewn up a T top. I would like to be reasonably accurate on stitching details for the new Touring top. I decided against the top kit route and purchased the necessary fabric for the new top. I would like to be as correct as I can with the top details.
Can someone with a 12 Touring top that you believe to be accurate take the following measurements for me:
1. What is the cross body width for the front to back sewn seams that is the wide center top Fabric (about 40 inches?)
EDIT: IS THE WIDE CENTER TOP FABRIC THE SAME WIDTH FRONT TO BACK?
2. Is the sewn seam on the lower edge of the top (front to back) single stitched or 2 rows of stitching?
3. How many murphy fasteners are on each side of the vertical edge of the roll up rear panel/window? I have seen pictures with just 2 per side including the bottom double Murphy style fasteners or 3 or 4 per side including the double fastener?
Any assistance much appreciated.
Bill
Re: A few questions about 12 Touring Top
Post by Allan » Mon Feb 24, 2025 7:09 pm
Bill, you may be able to get those details from the makers of the top kits. They will have done it before.
I bought a top kit for my Canadian bodied tourer to tap into their knowledge. Then I had a motor trimmer fit it. I did order it with no fittings in the side curtains so we could put those in just where the body and top irons indicated they should be.
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Mon Feb 24, 2025 8:48 pm
Allen,
I have thought about making such a contact however it is asking a lot when I did not order a kit from them. Which is why I ask on the forum.
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Wed Feb 26, 2025 4:20 pm
Bump, Who has a 12 Touring?
Stu Tomlinson
First Name: Stuart
Last Name: Tomlinson
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
Post by Stu Tomlinson » Wed Feb 26, 2025 6:15 pm
I just measured mine and they are right at 47 inches. Let me know if you need more info.
Stu
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Wed Feb 26, 2025 7:40 pm
Stu,
Thanks for replying. Can you provide responses to my #2 and #3 questions in my original post?
Thanks,
Bill
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Feb 27, 2025 12:19 am
Bill,
I am away from my computer right now, but will be happy to share with you what I can about my late 1911.
I think the tops were the same for '11 and '12.
Keith
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Thu Feb 27, 2025 7:54 am
Keith,
Thanks for responding. I will look for your measurement/answers. Timing is appropriate. I am working with my upholstory/top guy to cover the new bows today.
Last Name: Tannehill
Post by JTT3 » Fri Feb 28, 2025 4:03 pm
Hope this helps a bit.
Post by Allan » Fri Feb 28, 2025 6:20 pm
From reading reports on the forum, those supplying top and upholstery kits have a really good reputation for quality products. Way back in 1990 my Carter's Cut n Cover kits worked a treat on my 1915 tourer. I could see no good reason to re-invent the wheel by starting from scratch with a custom made trim set, and schooling up a trimmer to make same. The time and angst finding all the parameters for the build, and then having a one off top made, was something my trimmer was reluctant to undertake, but he welcomed fitting a ready made kit. At the time it cost me way less due to the time it didn't take to design it form scratch. A big plus was it was made from materials which were not readily available here in Australia at the time.
I would go the same route in a heartbeat if I had a Ford factory car to work on again.
Stu Tomlinson
First Name: Stuart
Post by Stu Tomlinson » Fri Feb 28, 2025 6:30 pm
Yes the sewn seem is the same width front to back
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Feb 28, 2025 6:34 pm
Hope these help:
These are the dimensions on my top.
Note the vertical bows should be close to the same height.
-Keith
Stu Tomlinson
First Name: Stuart
Post by Stu Tomlinson » Fri Feb 28, 2025 6:36 pm
I just saw the attachment Keith sent. That nailed it exactly
Last Name: Hjortnaes
Post by DHort » Sat Mar 01, 2025 3:37 pm
John
Did Vince make diagrams like that for all years?
I have his video on DVD
dave
Post by JTT3 » Sat Mar 01, 2025 10:50 pm
I can’t say definitely but I have seen 09/10 & a 15 touring. I lost all that several years back when the shop was destroyed along with a table top computer unfortunately.
Best John
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Sun Mar 02, 2025 8:35 am
My thanks to all that responded. Keith Townsend established contact and with his Late 1911 touring has provided great photos and responses to my questions. I am off and running now with my trimmer making the new top. I am new to T's and this forum, what a great forum with helpful folks!
