Why is the intake runner so darn long??
drzomber
Topic author - Posts: 11
- First Name: Rob
- Last Name: Zomber
I'm new to T's (I have had a bunch of A's in the past) and don't understand why they make the intake runner so long. Even on aftermarket intakes (except for the Winfield) it seems excessive. I guess I could understand it if they were building a high revving engine but given the application it seems really odd to me. Can someone explain the reasoning to me??
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
Re: Why is the intake runner so darn long??
I believe that the length of the intake drop is intended to allow enough drop for the gravity fuel system. Some earlier body styles had a longer drop.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Tadpole
- First Name: Tad
- Last Name: Glahn
If you think Ford was bad, look at Chevrolet’s!
Longer, small bore intake manifolds work very well on low speed engines with mild cam profiles. Short, large bore intake runners with no manifold heat would give very poor results on a stock Model T engine, especially with the gasoline commonly available in the 1920s. An intake manifold can be "tuned", much as an exhaust header can be "tuned". Modified T engines that run at higher speeds with high lift, long duration camshafts and larger carburetors can take advantage of shorter, larger-bore intake runners.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
As Ed posted above, the gravity flow fuel system is the reason the carburetor sits so low and the intake is so long.
My father's 1910 IHC Model F roadster has overhead valves and has a much longer intake than a Model T Ford.
got10carz
- Last Name: Meixner
Here's my theory. The firing order is wrong. The model T is 1243 as are most early 4 cylinder cars. This requires the front 2 cylinders and rear 2 cylinders to suck 1 right after another. The long manifold has more fuel stored in the manifold. A better firing order would be 1324.
- First Name: craig
- Last Name: leach
The firing order on a T does as I understand causes a flow issue that would be rectified with a 1423 or 1324 configuration. Reversing the ports
has been tried with some success as I understand. Now that cams are being manufactured again maybe someone will bump the program & make
some. Kirk Wright built a 6 cylinder out of T engines & somewhere there are pics of him making the crank & cam. A stock came could be cut up
& put together to do this also. Didn't Winfield's 2up 2down engine have a modified firing order?
