Why is the intake runner so darn long??
drzomber
First Name: Rob
Last Name: Zomber
Post by drzomber » Sun Mar 16, 2025 10:09 pm
I'm new to T's (I have had a bunch of A's in the past) and don't understand why they make the intake runner so long. Even on aftermarket intakes (except for the Winfield) it seems excessive. I guess I could understand it if they were building a high revving engine but given the application it seems really odd to me. Can someone explain the reasoning to me??
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Re: Why is the intake runner so darn long??
Post by Ed Baudoux » Sun Mar 16, 2025 10:20 pm
I believe that the length of the intake drop is intended to allow enough drop for the gravity fuel system. Some earlier body styles had a longer drop.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Post by Tadpole » Mon Mar 17, 2025 8:25 am
If you think Ford was bad, look at Chevrolet’s!
Post by TXGOAT2 » Mon Mar 17, 2025 9:22 am
Longer, small bore intake manifolds work very well on low speed engines with mild cam profiles. Short, large bore intake runners with no manifold heat would give very poor results on a stock Model T engine, especially with the gasoline commonly available in the 1920s. An intake manifold can be "tuned", much as an exhaust header can be "tuned". Modified T engines that run at higher speeds with high lift, long duration camshafts and larger carburetors can take advantage of shorter, larger-bore intake runners.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Mon Mar 17, 2025 7:38 pm
As Ed posted above, the gravity flow fuel system is the reason the carburetor sits so low and the intake is so long.
My father's 1910 IHC Model F roadster has overhead valves and has a much longer intake than a Model T Ford.
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Mon Mar 17, 2025 8:13 pm
Here's my theory. The firing order is wrong. The model T is 1243 as are most early 4 cylinder cars. This requires the front 2 cylinders and rear 2 cylinders to suck 1 right after another. The long manifold has more fuel stored in the manifold. A better firing order would be 1324.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Mar 17, 2025 9:52 pm
The firing order on a T does as I understand causes a flow issue that would be rectified with a 1423 or 1324 configuration. Reversing the ports
has been tried with some success as I understand. Now that cams are being manufactured again maybe someone will bump the program & make
some. Kirk Wright built a 6 cylinder out of T engines & somewhere there are pics of him making the crank & cam. A stock came could be cut up
& put together to do this also. Didn't Winfield's 2up 2down engine have a modified firing order?
Craig.
