Shift handle idea's
got10carz
Topic author - Posts: 589
- Last Name: Meixner
Shift handle idea's
I'd like to fabricate a shift handle from a Model T part. I need idea's!! I don't want something to big a clumsy. Lamp part, trans part, carb part, anything.
- First Name: Austin
- Last Name: Farmer
Re: Shift handle idea's
Well, you could use a foot pedal, just the top, and really confuse people and say its the gas pedal...
Or an old rear axle roller bearing. Might be a bit more ergonomic.
Maybe an old bushing or radiator cap.
Just a few ideas
Just a few ideas
NoelChico
- First Name: Noel
- Last Name: Chicoine
A hubcap. You'd need to fill the center and drill/thread it.
WillyR
- First Name: Vilhelm
- Last Name: VonRaschke
- * REQUIRED* Type and Year of Model Ts owned: 1924 coupe
ebay search "lucite rat fink shift knob"
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
- Last Name: Humble
A model T "top prop nut" is a good size and shape. Female 7/16-14 threads.
I prefer old crystal door knobs !
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
I modified and used a solid brass 1.5 inch walking stick handle on my warford shifter.
Last edited by ThreePedalTapDancer on Tue Apr 08, 2025 2:25 pm, edited 1 time in total.
TFan
- First Name: Jim
- Last Name: Riedy
Had this on my workbench at work for years. Jim
zrusscher
- First Name: Zaeden
- Last Name: Russcher
- * REQUIRED* Type and Year of Model Ts owned: None Yet, Hope for a 23-27 Touring
It may not be a part from a Model T, but I couldn't resist. Just get a half dollar with a year correct to your car.
You could adapt a front outer wheel bearing. That way you don't have to worry about RSI in your wrist!
Brian D
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
The repop of the radiator topper of Henry's Head!
- Attachments
- images.jpeg (7.38 KiB) Viewed 5560 times
Life is Good, be nice.
Agate would be period-correct.... or you might get a Betty Boop doll head and fill it with Bondo, then drill and tap.
OK, you are excused from installing any Betty Boop items.
Used in all my daily drivers since 1965. If you decide to use something that needs to be filled and tapped... Get a nut that fits the shift shaft & fill with Durhams Rock Hard Putty. You might press a bolt (wrapped with Teflon tape) with the nut into the putty and remove the bolt when putty hardens.
Could use Bondo too but the putty flows more easily
Dennis_Brown
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
You are in Minn. Lookaround a flea market and find a hame with a brass know on the end and use that. If you are not familiar with the term, a hame was part of a harness used on horses.
What year is it for - see eBay
got10carz
I choose Noel's idea. I did like the walking stick handle with a Liberty dollar also, just not a T part.
Michael Peternell
- First Name: Michael
- Last Name: Peternell
A 1910 correct hubcap! Oh the blasmany!
