Shift handle idea's
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Shift handle idea's
Post by got10carz » Tue Apr 08, 2025 12:49 pm
I'd like to fabricate a shift handle from a Model T part. I need idea's!! I don't want something to big a clumsy. Lamp part, trans part, carb part, anything.
First Name: Austin
Last Name: Farmer
Re: Shift handle idea's
Post by 1925 Touring » Tue Apr 08, 2025 1:08 pm
Well, you could use a foot pedal, just the top, and really confuse people and say its the gas pedal...
Or an old rear axle roller bearing. Might be a bit more ergonomic.
Maybe an old bushing or radiator cap.
Just a few ideas :idea:
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Tue Apr 08, 2025 1:11 pm
A hubcap. You'd need to fill the center and drill/thread it.
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Post by WillyR » Tue Apr 08, 2025 1:35 pm
ebay search "lucite rat fink shift knob"
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Apr 08, 2025 1:37 pm
A model T "top prop nut" is a good size and shape. Female 7/16-14 threads.
Post by RajoRacer » Tue Apr 08, 2025 1:43 pm
I prefer old crystal door knobs !
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Apr 08, 2025 2:09 pm
I modified and used a solid brass 1.5 inch walking stick handle on my warford shifter.
Last edited by ThreePedalTapDancer on Tue Apr 08, 2025 2:25 pm, edited 1 time in total.
Post by Jerry VanOoteghem » Tue Apr 08, 2025 2:15 pm
My choice also!
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Tue Apr 08, 2025 4:36 pm
Had this on my workbench at work for years. Jim
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Apr 08, 2025 4:45 pm
Something from Langs?
Vern (Vieux Carre)
zrusscher
First Name: Zaeden
Last Name: Russcher
* REQUIRED* Type and Year of Model Ts owned: None Yet, Hope for a 23-27 Touring
Post by zrusscher » Tue Apr 08, 2025 5:05 pm
It may not be a part from a Model T, but I couldn't resist. Just get a half dollar with a year correct to your car.
Post by Allan » Tue Apr 08, 2025 5:54 pm
You could adapt a front outer wheel bearing. That way you don't have to worry about RSI in your wrist!
Brian D
First Name: Brian
Last Name: Dowell
* REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Post by Brian D » Thu Apr 10, 2025 4:05 am
The repop of the radiator topper of Henry's Head!
Life is Good, be nice.
Post by TXGOAT2 » Thu Apr 10, 2025 9:40 am
Agate would be period-correct.... or you might get a Betty Boop doll head and fill it with Bondo, then drill and tap.
Post by Jerry VanOoteghem » Thu Apr 10, 2025 11:54 am
... and then throw it in the trash.
Sorry, I can't stand Betty Boop :x :lol:
Post by TXGOAT2 » Thu Apr 10, 2025 12:10 pm
OK, you are excused from installing any Betty Boop items.
Post by TRDxB2 » Thu Apr 10, 2025 12:21 pm
Used in all my daily drivers since 1965. If you decide to use something that needs to be filled and tapped... Get a nut that fits the shift shaft & fill with Durhams Rock Hard Putty. You might press a bolt (wrapped with Teflon tape) with the nut into the putty and remove the bolt when putty hardens.
Could use Bondo too but the putty flows more easily
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Fri Apr 11, 2025 10:28 pm
You are in Minn. Lookaround a flea market and find a hame with a brass know on the end and use that. If you are not familiar with the term, a hame was part of a harness used on horses.
Post by TRDxB2 » Sat Apr 12, 2025 12:52 am
What year is it for - see eBay
got10carz
Last Name: Meixner
Post by got10carz » Thu Apr 17, 2025 4:29 pm
I choose Noel's idea. I did like the walking stick handle with a Liberty dollar also, just not a T part.
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Thu Apr 17, 2025 8:10 pm
A 1910 correct hubcap! Oh the blasmany!
