Best location for vent on warford
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Sun May 04, 2025 9:42 am
Looking for information on best location on the shift tower of Layne warford to drill & install the Layne supplied vent.
Thank you in advance.
John M
Oscoda, Mich
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: Best location for vent on warford
Post by got10carz » Sun May 04, 2025 10:42 am
This is where I was told to install one by someone knowledgeable. Where the bolt is sitting. I used a 1/4" pipe thread cintered bronze vent.
Post by Mark Gregush » Sun May 04, 2025 10:45 am
The Ford Model A transmission has a vent hole on the shift tower.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Sun May 04, 2025 11:22 am
The later Layne Warfords come with a vent. See picture for location. You guess looks pretty good.
1926 Tudor
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon May 05, 2025 12:10 pm
Perhaps a dumb question, but I have two original aluminum Warfords and I can't remember seeing a vent on either one of them. Maybe I've over looked them. If the original Warfords didn't have them, why are they recommended, now?
Nunsio1
Post by Nunsio1 » Mon May 05, 2025 3:30 pm
The Warford offered by Layne Machine Works build up internal pressure & weep oil out of the shift rail area. Layne puts in vents in all of their units now.
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Mon May 05, 2025 8:31 pm
I drill the top of my fill plug and seems to help.
Fitz
Nunsio1
Post by Nunsio1 » Tue May 06, 2025 11:19 am
Gentleman , thanks for all input, I have drilled fill plug & installed vent hose over fuel tank w/ catch bottle, getting some fluid after some miles.
One additional question.. all photos show brass vent location at rear of shift tower. Can it be installed at front area of the tower?
Post by Jerry VanOoteghem » Tue May 06, 2025 12:13 pm
I would guess that the modern Warfords use modern seals and are well contained, whereas the originals were probably "ventilated" due to the poor sealing technology of the era.
