Best location for vent on warford
Nunsio1
Topic author - Posts: 119
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Looking for information on best location on the shift tower of Layne warford to drill & install the Layne supplied vent.
Thank you in advance.
John M
Oscoda, Mich
John M
Oscoda, Mich
got10carz
- Last Name: Meixner
Re: Best location for vent on warford
This is where I was told to install one by someone knowledgeable. Where the bolt is sitting. I used a 1/4" pipe thread cintered bronze vent.
The Ford Model A transmission has a vent hole on the shift tower.
John.Zibell
- Last Name: Zibell
The later Layne Warfords come with a vent. See picture for location. You guess looks pretty good.
1926 Tudor
ModelTWoods
- First Name: Terry
- Last Name: Woods
Perhaps a dumb question, but I have two original aluminum Warfords and I can't remember seeing a vent on either one of them. Maybe I've over looked them. If the original Warfords didn't have them, why are they recommended, now?
Nunsio1
The Warford offered by Layne Machine Works build up internal pressure & weep oil out of the shift rail area. Layne puts in vents in all of their units now.
Ralph F
- First Name: Ralph
- Last Name: Fitz-Gerald
I drill the top of my fill plug and seems to help.
Fitz
Fitz
Nunsio1
Gentleman , thanks for all input, I have drilled fill plug & installed vent hose over fuel tank w/ catch bottle, getting some fluid after some miles.
One additional question.. all photos show brass vent location at rear of shift tower. Can it be installed at front area of the tower?
I would guess that the modern Warfords use modern seals and are well contained, whereas the originals were probably "ventilated" due to the poor sealing technology of the era.ModelTWoods wrote: ↑Mon May 05, 2025 12:10 pmPerhaps a dumb question, but I have two original aluminum Warfords and I can't remember seeing a vent on either one of them. Maybe I've over looked them. If the original Warfords didn't have them, why are they recommended, now?
