I am putting a top on my 1914 T roadster and would like to know how far the rear bow extends past the tack strip. I have looked at a lot of drawings and found that the 1911 touring extends 4 ½”, the 1912 touring extends 4” and the 1916 Touring extends 4” I have found nothing on the 1913 or 14 roadsters.
Has anyone looked into this problem and if so is willing to help me with a measurement?
Are the 1913-15 roadster tops all the same?
Thank you
Craig
1914 Roadster top installation
Craig E. Luton
Topic author - Posts: 191
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
- First Name: Keith
- Last Name: Townsend
Re: 1914 Roadster top installation
Craig,
The rear curtain of the top generally follows the trajectory of the backrest outside of the body.
-Keith
-Keith
- Last Name: Tannehill
- Board Member Since: 2002
Keith you make the complex simple. Thanks for your experience & explanation.
Best John
Best John
1915ford
- Last Name: Cameron
- * REQUIRED* Type and Year of Model Ts owned: 1909touring 1915 touring
Three to 3.5 inches. Drop two plumb bobs from the back bow 12 inches from center and measure over to the tack rail.
