1914 Roadster top installation
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Thu May 29, 2025 9:32 pm
I am putting a top on my 1914 T roadster and would like to know how far the rear bow extends past the tack strip. I have looked at a lot of drawings and found that the 1911 touring extends 4 ½”, the 1912 touring extends 4” and the 1916 Touring extends 4” I have found nothing on the 1913 or 14 roadsters.
Has anyone looked into this problem and if so is willing to help me with a measurement?
Are the 1913-15 roadster tops all the same?
Thank you
Craig
First Name: Keith
Last Name: Townsend
Re: 1914 Roadster top installation
Post by KWTownsend » Thu May 29, 2025 9:57 pm
Craig,
The rear curtain of the top generally follows the trajectory of the backrest outside of the body.
-Keith
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri May 30, 2025 9:11 am
Keith you make the complex simple. Thanks for your experience & explanation.
Best John
1915ford
Last Name: Cameron
Post by 1915ford » Fri May 30, 2025 9:13 am
Three to 3.5 inches. Drop two plumb bobs from the back bow 12 inches from center and measure over to the tack rail.
