Henry, we have a problem!
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Jul 09, 2025 10:56 pm
1910 touring, original saddles, reproduction top sockets with the following measurements:
Top socket width 1-45/128"
Saddle gap width 1-27/128"
Now what to do?
Does anyone have a pair of top saddles that have a wider gap that are the same profile? I think the early saddles are cast so heating and bending is out if they are cast I suppose & would hate to squish the socket. Any ideas?
Dennis Prince
Last Name: Prince
Re: Henry, we have a problem!
Post by Dennis Prince » Thu Jul 10, 2025 12:09 am
If they are cast steel they can be heated and bent, if cast iron that won't work.
Post by Original Smith » Thu Jul 10, 2025 12:19 am
There is your problem! You have repro sockets.
Post by JTT3 » Thu Jul 10, 2025 1:17 am
Larry if originals were available it would be on the T.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jul 10, 2025 5:40 am
Not hard to make from steel fabrication process in pieces, weld, braze, shape, then texture prior to painting.
Been there, Done that before.
Post by RajoRacer » Thu Jul 10, 2025 11:06 am
John - enlighten me on how you came of those measurements - what measuring instrument was used ?
Post by JTT3 » Thu Jul 10, 2025 11:50 am
Digital Calipers, socket measured on the 90’s width on the saddle & a physical fitting that failed to seat in the saddles. Best John
Post by Jerry VanOoteghem » Thu Jul 10, 2025 12:16 pm
I wondered about the same thing. :)
Post by Original Smith » Thu Jul 10, 2025 1:45 pm
There is a fellow in Auburn California that has been making top sockets for over 50 years. I have never heard of a complaint!
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Jul 10, 2025 2:27 pm
Ron Brown. I think he retired.
Post by RajoRacer » Thu Jul 10, 2025 2:45 pm
Yes, he's long gone - John Borinaukus (SP) has been remanufacturing top irons for many years.
Post by JTT3 » Thu Jul 10, 2025 3:59 pm
Thanks for the information & solved. In this case I don’t want to spend another thousand to solve an issue that might be resolved for a couple hundred. Hank may have the viable solution however I have seen larger saddles with the same profile on larger cars of the era. Hoping someone has a set, if not it’s a welding opportunity that Hank suggested.
Let me know if in your stash of stuff you may have a set of the larger ones as described. Best John
Post by DanTreace » Thu Jul 10, 2025 5:20 pm
You might call this outfit , may have a saddle that fits.
Post by RajoRacer » Thu Jul 10, 2025 5:40 pm
John - what would the width of the saddle you need in American inches to the closest 1/16" ?
Post by DanTreace » Thu Jul 10, 2025 9:14 pm
This is the measure made on the socket diameter.
That would be about 1 3/8" diameter, give or take.
But remember the saddle will have a leather strap laying in the curve, so you have to add that thickness too.
Post by Allan » Thu Jul 10, 2025 10:00 pm
John, I think some of us had difficulty getting our heads around measuring things in so many 128ths. That is weird! 45/128" is approx 3/8", give or take 7/128", which is almost 1/16"
Post by JTT3 » Fri Jul 11, 2025 8:48 am
Yeah I get it Allan it’s what I was given. Thanks for the conversion. Still looking. Thanks for the input.
John
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Jul 11, 2025 9:00 am
Steve, when did he pass away ? Very sorry to hear this.
When a falling tree branch damaged the top on my ‘13 runabout in September of 2020, Langs put me in touch with him. At the time, he said he was having health issues, but would contact me when he was working again. True to his word, he called me back within a few months, and soon had my damaged irons repaired. A fine gentleman, a pleasure to deal with, and another Model T friend I had the pleasure to correspond with. We have lost another treasured companion on the road to the T.
Get a horse !
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Jul 11, 2025 9:19 am
Dan, is there a specification for the thickness (weight) of the strap leather ? Diameter of the rolled strap can be adjusted by skiving down the thickness of the strap.
Get a horse !
Last Name: Patrick
Post by jiminbartow » Fri Jul 11, 2025 10:17 am
I would find a steel pipe with the correct diameter then heat and straighten the saddle, insert the pipe and heat the saddle and fold the ends up and around the pipe. Since it is of no use the way it is, nothing ventured, nothing gained. If you are unsure if you are able to do it, I’m sure a local fabrication shop will be able to figure out how to do it. At the Railcar shop I used to work at, they faced these situations all the time, as they were required to make new parts for old obsolete railcars. A good fabrication shop could almost certainly make you new identical resized saddles out of mild steel.
Post by RajoRacer » Fri Jul 11, 2025 11:39 am
My apologies - I meant "long gone" as in retired ! Erik B. would know if he's still on the planet.
