Transmission issues
nathanw90
First Name: Nathan
Last Name: Warburton
* REQUIRED* Type and Year of Model Ts owned: 1919 Roadster Pickup
Transmission issues
Post by nathanw90 » Mon Jul 14, 2025 8:07 pm
So, after a long winter off the road doing wheels, rear end, new axles and kingpins, took her for the first drive today.
Had a rotational knock noise only when rolling, and not consistent. Would happen once then fine for awhile. I thought possibly pin for the u joint slipping out. I was right. Fixed that. Drove it around again and after awhile, same noise again. Only when rolling. So I check the pin again, it's fine.
I now dig deeper. Took the cover off the hogs head and pressed each pedal. When I press reverse, I can see the triple gear that's visible, move up and down. I thought to myself, that should NOT happen! So I turn the engine over and check the others. Another was just as bad and the 3rd was as bad, but moved.
Engine and trans was professional rebuilt about 3 years ago. Was done by a guy who does mostly only T and A engines. Came recommended by Langs. He did say the trans looks to never of been touched. It did need bushings he said.
Always had a good oil level, use the Lucas classic car stuff. Changed it often. I'd say it has less than 500 miles on the rebuild.
I have a message into the rebuilder. See if he has any insight on what's going on.
Any suggestions?
Last Name: Tannehill
Board Member Since: 2002
Re: Transmission issues
Post by JTT3 » Mon Jul 14, 2025 11:00 pm
If I understood what your were trying to explain is that your triple gears are moving aft toward the drums & forward towards the flywheel on the triple gear pins. Is that correct? If so you may have some issues. The triple gears are only engaged in low & reverse however if not checked for correct tolerances (0.006-0.010) with new bushing you can have some slight movement but not much, if you used the old bushings and the flange face of the bushings are way below the minimum height you’ll have even more movement. Based on the information you gave that shouldn’t be the case. Other things to consider are loose pins, loose bushings in the triple gears because running tolerance were too tight & the bushings seized on the pins. In addition could be your clutch basket wasn’t properly spaced & locked down causing some drum float. If I’m not mistaken a clearance of 0.015-0.022 is within tolerance but if the clutch basket pin is not set correctly it can cause the drums to float a bit. In my opinion you should consider pulling the engine and check your transmission others may have a different opinion. Best John
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jul 15, 2025 12:45 am
Reach in and attempt to move each triple gear around and see if there is excessive slop of if you are able to move/rotate the gear from side to side (not rotate on the pin) or move it radially toward the outside of the flywheel. Check each one- its possible as John mentioned above that one of the triple gears seized on the shaft and spun the pin in the flywheel or the bushing has started to disintegrate. Just one thing to check before moving ahead. Best of luck!
Post by TXGOAT2 » Tue Jul 15, 2025 7:26 am
Be sure your motor mounts are tight.
J and M Machine
Last Name: Gulbankian
Post by J and M Machine » Tue Jul 15, 2025 9:20 am
Sounds like you'll have to pull the engine. and take the flywheel off and see what happened to the transmission.
If you 've changed the oil like you mention then this shouldn't of happened unless it had no oil in it or rebuilder didn't do it correctly.
Greg sarky k
First Name: Gregory
Last Name: Kojoyian
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo,1912 Touring,1912 Torpedo ,1913 Touring
Post by Greg sarky k » Tue Jul 15, 2025 9:44 am
Sounds like the engine was rebuilt incorrectly. If you can see the triple gears moving then the bushings are bad. This sounds like you need to replace the triple gear pins and bushings because they wear out together. Could also be transmission problems you are not yet aware of.
Here’s my suggestion if you don’t want anymore headaches, I would pull the engine and take it to J and M Machine in Southboro Ma which is not that far from you..They are a true top tier machine shop,true pros.They have done 4 T engines for me and I have never had any issues..
What happened to you should not happen but unfortunately it does..I don’t know who did your engine but I do know of one unscrupulous builder in Massachusetts so yeah, it happens.
Good luck.
nathanw90
First Name: Nathan
Post by nathanw90 » Tue Jul 15, 2025 11:20 am
No, not only after and forward, but up and down significantly
nathanw90
First Name: Nathan
Post by nathanw90 » Tue Jul 15, 2025 11:22 am
Rebuilder claims quality of bushings may be the issue.
Will be pulling it this weekend and taking apart. Will come back and update with my findings.
Post by speedytinc » Tue Jul 15, 2025 11:23 am
Before pulling the motor, have a competent & knowlegable T mechanic like J & M look & confirm the problem.
Its only fair to see if the original builder will warrant his work.
nathanw90
First Name: Nathan
Post by nathanw90 » Tue Jul 15, 2025 11:31 am
Good luck.
J&M was my first quote, it's was more than the car was worth. I shopped around. Like I said, the rebuilder I chose has good reviews on here and came recommended.
I do know of that rebuilder you're talking about, tried them too, got an awkward response so I didn't proceed.
It went to NY for rebuild. Not naming because this isn't to bash anyone, just simply looking for insight.
Post by speedytinc » Tue Jul 15, 2025 11:42 am
With this new information, disregard my email.
Getting triple gear bushings correct & living long is a real technical skill unto itself.
They seem to be the weakest link, especially @ initial start up.
I will add, its not out of the realm of possibility to have a failure by operator error.
I once did a fellows THIRD succession triple gear bushing failure. Couldn't figure out why untill he picked up the finished T. The poor transmission screamed in agony as he backed out of my driveway. This fellow has big feet & cant see the pedals. He was engaging low & reverse simultaneously.
That tore the bushings up fast. Once made aware, no more worn out bushings/gears.
It is typical for a motor rebuild to cost more than you paid for the T.
$6k is cheap for a good, but not total overhaul. $10k in more realistic in TODAY's $$$.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Jul 15, 2025 12:26 pm
Post by TXGOAT2 » Tue Jul 15, 2025 12:36 pm
"So, after a long winter off the road doing wheels, rear end, new axles and kingpins, took her for the first drive today..."
What caused the triple gear issue to develop while the car was out of service for rear axle repairs?
Could there be some issue with the newly-overhauled rear axle?
nathanw90
First Name: Nathan
Post by nathanw90 » Tue Jul 15, 2025 12:52 pm
Dan, just pm'd you. Sorry didn't even realize that you replied!
Post by TXGOAT2 » Tue Jul 15, 2025 4:04 pm
Triple gear bushings need adequate lubrication, and using a high quality, light bodied oil with high film strength in a stock T should facilitate that. As I understand it, the triple gears are idle when running in "high". Using the correct oil and allowing the engine/transmission to warm up thoroughly before running hard or fast in low gear or reverse may help the bushings survive. Keeping speeds down when running in low is probably a good idea. Needle bearings are widely used in modern automatic transmissions, and they seem to hold up very well.
Greg sarky k
First Name: Gregory
Last Name: Kojoyian
Post by Greg sarky k » Tue Jul 15, 2025 4:07 pm
Well, maybe but I think you will find that the money you spend to get it fixed after the first guy messed it up and the new money you will pay someone who may able to do it correctly, will probably add up to be the same cost as a top machine shop like J and M.
So I understand the money issue but unfortunately for all of us ,the old adage still holds true. Good engine building isn’t cheap and cheap engine building isn’t good.
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Jul 15, 2025 7:22 pm
You said
"Rebuilder claims quality of bushings may be the issue."
Reminds me of the carpenter who kept bending nails while hammering studs who camplained. "Damn Chinese nails!" :lol:
Post by JTT3 » Tue Jul 15, 2025 8:16 pm
So i reread your post carefully and wanted to ask several questions without jumping the shark on the builder until you know what you don’t know. You said you rebuilt the rear axle, did that include the modern pinion set up with a locking collar for the preload? Generally speaking, did you use a new pin for the universal & peen it over on both sides or the original pin same process. You said you have about 500 miles on the engine, paraphrased, how many of those miles were prior to doing the things over the winter months for the T you mentioned but after the rebuild? Did you have any issues during those miles prior to the rear axle being rebuilt? A u joint pin that is not tight & peened in the orifice can be slung out and “can” wedge against the driveshaft bell housing doing real damage to the transmission if in low, reverse & even catastrophic to the total engine assembly in high though not typically. I asked about the modern pinion bearing assembly. If you did use it, the Allen head bolt can sit very proud and cause a knock against the drive shaft housing but I haven’t witnessed or heard of that stalling an engine. As long as the engine didn’t receive any damage, minus the transmission damage, a rebuild on the problem parts will not be too costly though time consuming & aggravating. You said you’re pulling the engine, do not disassemble the engine until you let the professional build inspect it. You don’t want to alter anything until they have done so if you expect them to warranty the build. If you are there during disassembly on the transmission a simple measurement on the triple gear bushing flange & pins will reveal a lot of information for you too consider. If you’ve decided to do disassemble disregarding any warranty, be sure to index the location of the transmission shaft to the crank shaft & the drive plate to the brake drum if it was aligned & balanced. Wishing you the best of luck & a well working T post repair. Best John
nathanw90
First Name: Nathan
Post by nathanw90 » Wed Jul 16, 2025 10:00 am
So i reread your post carefully and wanted to ask several questions without jumping the shark on the builder until you know what you don’t know. You said you rebuilt the rear axle, did that include the modern pinion set up with a locking collar for the preload? Generally speaking, did you use a new pin for the universal & peen it over on both sides or the original pin same process. You said you have about 500 miles on the engine, paraphrased, how many of those miles were prior to doing the things over the winter months for the T you mentioned but after the rebuild? Did you have any issues during those miles prior to the rear axle being rebuilt? A u joint pin that is not tight & peened in the orifice can be slung out and “can” wedge against the driveshaft bell housing doing real damage to the transmission if in low, reverse & even catastrophic to the total engine assembly in high though not typically. I asked about the modern pinion bearing assembly. If you did use it, the Allen head bolt can sit very proud and cause a knock against the drive shaft housing but I haven’t witnessed or heard of that stalling an engine. As long as the engine didn’t receive any damage, minus the transmission damage, a rebuild on the problem parts will not be too costly though time consuming & aggravating. Wishing you the best of luck & a well working T post repair. Best John
I believe that the drive shaft pin is completely unrelated. It was reused, peened, but I suppose not good enough. The car continued to move no problems.
The rear end was mostly cleaned, inspected, new seals, new good roller and sleeve on one side and new axles with new keyways.
I'm thinking the pins for the triple gears are the issue. Not well looked over possibly, and or the bushings not honed/reamed correctly.
Really interested in the triple gears with the needle bearings. Would certainly upgrade to that if the gentleman gets back to me.
I should have an update this weekend, once I have it out and apart!
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Jul 16, 2025 11:06 am
You will need a new flywheel and pins.
When the pins get loose, there is little you can do.
Post by JTT3 » Wed Jul 16, 2025 11:09 am
Dan’s triple gear bearings are incredible, if you’ve decided to go that route buy his triple gear pins with the bearings. It’s really a must do unless you’re a glutton for punishment, ha!
Best John
nathanw90
First Name: Nathan
Post by nathanw90 » Wed Jul 16, 2025 12:28 pm
Best John
That's the plan! I've reach out on here, email, next I'll call if I don't hear back by next week!
Post by Jerry VanOoteghem » Wed Jul 16, 2025 2:39 pm
Did somebody state that this is the problem?
Post by TXGOAT2 » Wed Jul 16, 2025 3:10 pm
You might try putting the car in "high", engine off, and have someone rock it forward and backward to see if the noise occurs, and you could also look into the transmission while the load is changing, and try applying the different bands while the car is being rocked. You might want to take out the spark plugs and have someone crank the engine while you observe the transmission's innards and apply the bands, etc. Cranking the engine with the rear wheels off the ground is another option. With the rear wheels off the ground, blocking one wheel and putting the car in gear and yanking the other wheel back and forth might help localize the sound.
J and M Machine
Post by J and M Machine » Wed Jul 16, 2025 4:50 pm
Thanks for the vote of confidence.
If we look at it ,you know what we're going to find
Problem with a Model T is it all has to be done, there is no 50%. The first 50% will affect second 50% and vice versa.
If they didn't do transmission, though did engine part all the dirt from flywheel and magnets will reintegrate with the engine part.
As seen in submitted picture of babbitted rear main bearing with debris stuck in it as babbitt does.
You'll see the bronze speckles .
second picture is dirty transmission. Just can't expect to get these clean by washing alone.
Money well worth doing it right rather than doing it twice.
Post by RajoRacer » Wed Jul 16, 2025 7:40 pm
That one has seen a few miles !
Dan McEachern
First Name: DAN
Post by Dan McEachern » Fri Jul 18, 2025 12:16 am
Nathan- just FYI, I have replied to your e-mail. Dan
nathanw90
First Name: Nathan
Post by nathanw90 » Sat Jul 19, 2025 5:19 pm
Almost have the engine ready to come out.
I will be going with Dans triple gears with needle bearings as a replacement.
Will update on my findings tomorrow when it's out and apart.
Post by RajoRacer » Sat Jul 19, 2025 7:02 pm
First issue I see is that accessory 4th main bearing !
nathanw90
First Name: Nathan
Post by nathanw90 » Sat Jul 19, 2025 7:59 pm
That's going away..
Post by speedytinc » Sat Jul 19, 2025 8:38 pm
If that bearing went out, & they do, could be a source of noise.
nathanw90
First Name: Nathan
Post by nathanw90 » Sat Jul 19, 2025 8:55 pm
It's been fine, but I do get and oil drip in the area. I recall being told.. "be sure to pack the unjoint with grease" when picking up the rebuild.
I believe I have a rebuildable core for Gene French to rebabbit out of another drivetrain I have. That what I'll be doing.
Post by Jerry VanOoteghem » Sat Jul 19, 2025 9:37 pm
Depending on the fourth main bearing that's been used, it's common to have to reduce the diameter of the output shaft in order to fit the ball bearing. If that's been done, just swapping out a Gene French rebabbitted 4th main is not so easily done.
As for any other problems that may exist, there has been a lot of speculation & opinion here. Don't get your mind made up in advance as to what is wrong. Careful inspection will be the only sure way to know. Hope it's something trivial and easily corrected.
Last Name: Hatch
Post by Dan Hatch » Sun Jul 20, 2025 6:53 am
Be sure driven plate is turning true to brake drum. Or you will be in here again. T transmission work is not just swapping parts.
nathanw90
First Name: Nathan
Post by nathanw90 » Sun Jul 20, 2025 9:40 am
Woah woah relax everyone.
Everything's going to be done right.
Car isn't even all apart yet!
TBC
nathanw90
First Name: Nathan
Post by nathanw90 » Sun Jul 20, 2025 3:17 pm
It's all apart, well mostly. I'm deep enough to see the problem.
One triple gears bushing face chewed up, pin spun in flywheel.
Looks like a flywheel will be needed.
Post by speedytinc » Sun Jul 20, 2025 4:40 pm
The pins are larger @ the base than the flywheel hole. They install from the magnet side & must be removed in the opposite direction. Never pushed thru. The pins must be a tight press fit. This appears to be your failure point. Pin bushing surfaces must be polish smooth. I understand some of the vender supplied pins are not.
The bushing face must be surfaced down to about .010 proud of the gear face. Specs in the service manual.
I believe it necessary to chamfer or re-chamfer the bushing face to the outside edge of the oil groves & be sure there is a good transition from the chamfer into those oil groves. (not done here) Plenty of oil is critical to the bushing. Assemble with oil, never grease.
Follow ALL specs from the service manual. The combination is critical for all the pieces to run in harmony.
Such a spec is the clearance between the driven gear & shaft face, it is deeper than flush.
Last Name: Hatch
Post by Dan Hatch » Sun Jul 20, 2025 4:40 pm
Do yourself a favor and find Herm’s thread on rebuilding transmissions. He has a lot of good time proving ideas.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Jul 20, 2025 4:54 pm
Had that happen after the hill climb one year. Noisy as all H***
Find a good flywheel with decent pins, and hone the bushings to fit. A stock car will be just fine. You'll need to rebalance the whole shebang.
My 2 cents.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Jul 20, 2025 4:56 pm
As stated, I bet the pins were changed incorrectly, or off spec.
Sorry that happened. It's a shame. At least it didn't grenade.
Post by Jerry VanOoteghem » Sun Jul 20, 2025 9:10 pm
Well, now we know the story. Sorry for you, but the good news is you caught it before more serious destruction occurred.
nathanw90
First Name: Nathan
Post by nathanw90 » Sun Jul 20, 2025 9:42 pm
Yep! Time to make it even better!
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Mon Jul 21, 2025 12:21 am
I have had to repair many transmissions with triple gear bushing failures. All of them were built with reproduction bushings and then set up too tight. Bushing seizes on the pin and either disintegrates or rips the pin out of the flywheel. Lang’s has Ford spec bushings but they are out of stock. The ultimate solution is Dan’s needle bearing gears. Second best is new triple gear pins and a set of original triple gears with Ford bushings. I have never seen a T transmission failure due to things being too loose. Always due to being too tight and inferior bushing quality.
nathanw90
First Name: Nathan
Post by nathanw90 » Mon Jul 21, 2025 7:51 am
Makes sense.
Rebuilder did new pins and bushings.
He did state to me when I replace everything, be sure to have .0005 to .0006 thousands. Which is more to a the recommended .0004.
Will be doing Dans gears and pins, working on getting a replacement flywheel and going to start setting it all up!
Post by TXGOAT2 » Mon Jul 21, 2025 8:42 am
How did Ford originally finish the triple gear bushings? Were they reamed, honed, or burnished?
How fast do the bushings turn on the pins in low gear at 7-8 MPH?
Triple gear bushing failure seems to be a not-uncommon issue today in newly-rebuilt transmissions, but to my knowledge, Ford factory-built Model Ts did not have a reputation for triple gear bushing failure.
Post by Scott_Conger » Mon Jul 21, 2025 10:28 am
"Running Fit" is a class of tolerance
Running or Sliding Fit can encompass any one of 9 sub-classes of fit from RC1 (Close Sliding Fit) all the way to RC9 (Loose Running Fit). FORD's ".002" Running Fit was likely an early equivalent to RC7 Free Running Fit or RC8 Loose Running Fit
Using the below calculator and entering ".677" for "nominal", "RC" for Running or Sliding Fit, and then either RC7 or RC8 and by going down to the "FIT" section, you will suddenly see that your final clearances are on a much looser side than you would imagine. Given that FORD's smooth broaches gave a nominal .004 clearance, and .005" clearance was at max limit, I'd imagine that FORD's class of fit would be defined today, by ANSI B4.1, as the upper limit of a RC7 Free Running Fit that is defined as ".0045" at it's upper limit.
FORD's ".002" was never a tolerance or final clearance fit - it was part of defining what class the "Running Fit" was.
https://amesweb.info/fits-tolerances/an ... lator.aspx
Glenn Chaffin had it right, years ago. I disagree with some of his explanation of how he applied the spec, but he was on the right track, and in fact his conclusion(s) and build philosophy were correct both in theory and practice. All the naysayers and folks who gave him no end of grief would have had even more time to disagree with him if they were not so busy re-rebuilding their transmissions.
Post by speedytinc » Mon Jul 21, 2025 11:25 am
I like your reasoned fit explanation.
I have had no issues/problems using .0045" boring in a lathe. My current method is with a pin sizer to .0045"
The service manual notes that a clearance of .006" or more required a new bushing.
Doesent leave much of a range for wear.
To further the confusion one only need to look @ the current vintage ford list of shaft & reamer sizes. Every bushing & shaft shows .002" size difference.
That guarantees bushing seizures. Anyone got an answer to these published specs?
Last Name: Juhl
Post by Oldav8tor » Mon Jul 21, 2025 11:30 am
i am very familiar with this problem. In 2019-2021 my newly rebuilt engine & transmission suffered a series of such failures beginning within a couple of months of getting it back on the road after a 30 year sleep. The rebuilder was very aware of the importance of adequate clearance between the pin and triple gear bushings and was never able to account for why my gears hung up. He did stand behind his work although I did provide the replacement parts.
Two of the gears/bushings seized on the pins and twisted them right out of the flywheel. One had the bushing seize on the pin and the gear spin on the bushing. I suspect the pins spun in the flywheel for quite awhile to produce that amount of wear.
Each time one failed it felt like the transmission seized up. Not knowing any better, I coaxed the car back into motion, which probably was when the pins spun free or the bushing broke free of the gear. I can remember three distinct events which I now associate with the failures. Since the 2nd rebuild I have put many thousands of problem-free miles on the car so I think it was done right this time.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Jul 21, 2025 11:53 am
I don't see any oil grooves in those.
Post by speedytinc » Mon Jul 21, 2025 12:12 pm
I rarely see a flywheel with the pin holes chewed out. The few were after current, poor rebuilds. I have seen several where the bushing seizes on the pin & the gear spins on the outside of the bushing. Even to the point of an hourglass type wear pattern in the bushing.
I suspect that such flywheel damage can be traced back to the builder gluing the bushing into the gear. (locktite) That kind of removes an unintended safety for when a bushing seizes to a pin. The un-seizure finds the point of least resistance. Just a thought.
Last Name: Hatch
Post by Dan Hatch » Mon Jul 21, 2025 2:11 pm
Look into “ burnishing bushings”. I am of the belief that Ford did some form of this to triple gear bushings.
Also look at ball sizing or burnishing. This is done with a harden ball of a special size to make the bushings a certain size.
nathanw90
First Name: Nathan
Post by nathanw90 » Mon Sep 01, 2025 7:56 pm
Update!
New (used) flywheel acquired thanks to Langs.
All cleaned up, pins measured for Dan.
New pins installed and weighed all the magnets. Cautiously laid them out. I used a harbor freight motorcycle wheel balancer to move the magnet weights around.
Work quite well. But now going to try it on the wheel balancer at work. If it looks easy enough and runout is okay, I'll do it. But otherwise I'll make a trip to a pro ;)
nathanw90
First Name: Nathan
Post by nathanw90 » Tue Sep 02, 2025 7:03 pm
So, I tried the wheel balancer method. I believe it worked well! I started being off balance by 15 grams.
