Not one, not two, but three!
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Thu Oct 23, 2025 10:36 pm
Pretty much as the title says. I have been cleaning my springs for my 24 roadster pickup build and have been uncovering a LOT of ford script. Some of the smaller springs had one stamping, a a few had two stampings. I got to the main spring on the bottom of the rear stack and uncovered 3 scripts on one leaf!
My question is why? Why so many? I can see one, two maybe, but three on the same piece?
Any ideas?
2 on the ends, and one faint one in the middle...
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Not one, not two, but three!
Post by Erik Johnson » Thu Oct 23, 2025 10:56 pm
Most likely because the raw bar stock was stamped every (insert number here) inches or feet before it was cut into the required lengths and then arched, etc.
Post by Allan » Fri Oct 24, 2025 12:55 am
My thoughts also Eric. Thwe rollers were likely made with the Ford imprint, and each time the roller completed a turn, a logo was left to fill the roller imprint.
Post by Original Smith » Fri Oct 24, 2025 1:30 pm
Some were in block letters too.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Fri Oct 24, 2025 3:02 pm
Larry,
Could those have been spurious or just different years (early or late)?
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Sat Oct 25, 2025 7:21 pm
Yes, a few of my Spring Leaves also had Ford script in block letters too.
Thanks guys, it would make sense that they would have dies that every so often would have a scripting stamp on it. Learn something new everyday! :)
