26 Window regulator needed
T. R. Quick
Topic author - Posts: 13
- First Name: Tom
- Last Name: Quick
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
I have a 26 Fordor drivers door window regulator that I’m needing the hand crank assembly for. Mine has a badly worn 6 tooth gear on the end. It causes the window to jump when this gear doesn’t mesh with the larger gear. Any help or direction would be appreciated!
Fordor forever
CamMan
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Re: 26 Window regulator needed
You might try building the tooth up with a welder and then file/grind it back to contour.
Joe Bell
- First Name: Joe
- Last Name: Bell
What style did you have? there is a couple different ones out there.
Agreed - a photo would be helpful !
T. R. Quick
- First Name: Tom
- Last Name: Quick
Gear is .5” dia. What is available is .7”. I tried to attach photo but I sbr see where I can do that her
Fordor forever
T. R. Quick wrote: ↑Tue Oct 28, 2025 2:24 pmGear is .5” dia. What is available is .7”. I tried to attach photo but I sbr see where I can do that her
You can start the process in one of two ways.
1. In your original post you will see a pencil icon - clock on it to edit that posting based on the instructions
2, Start a new post. It will require that you enter at least 10 characters (any) for the post to be accepted.
Sometimes the picture is to large to be accepted abd needs to be reduced You will get a yellow triangle instead of a green check mark, be patient for it to load. Use the PAINT app or equivalant to reduce it
INSTRUCTIONS
Locate the "Attachments" tab:
When creating a new post or reply, look for a tab labeled "Attachments" located below the text box. If you don't see it, look for a "Full editor" tab, which should make the "Attachments" tab appear.
Add your file:
Click on "Attachments," then select "Add Files". This will open a file browser on your computer.
Select the photo:
Navigate to the folder where your picture is saved, select the file, and click "Open".
--see it load green check mark is a success, yellow trangle to big a fail
Place the photo:
After the upload is complete, click "Place Inline." This will insert the photo into your message where your cursor was last placed.
Preview and submit:
Click the "Preview" button to see how your post will look. If you are satisfied, click "Submit" to finish.
henryford2
- First Name: Joseph
- Last Name: Andulics
Is this what you need? If so message me you address and I'll send one out to you. These were water jet cut, you may or may not need to do some finesse filing, they are not hardened.
henryford2
sorry reread the post, not what you need.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Some parts carried over to Model A's so here are some parts to think about.
Do your due diligence and make sure they are the parts you need, Model A parts sellers usually do not know Model T parts.
A-48104 6 Tooth Regulator Repair Kit
https://modelastore.com/index.php?route ... ct_id=5246
A-48102-L Left Window Regulator - 4 Hole
https://modelastore.com/index.php?route ... ct_id=5243
A-48102-R Right Window Regulator- 4 Hole
https://modelastore.com/index.php?route ... ct_id=5244
