Helping a Friend with a Promise
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Oct 25, 2025 2:21 pm
From years back.., keeping my word to assist in the parts that do not exist. Installing a Vega Steering Box, High angle wedge for the column drop, and custom billet aluminum windshield stanchions. Posting this to show others how to do it. The key in making these, you must use a variable speed metal capable band saw at half speed, canning wax as a lubricant, and patience.
Please Note: Not interested in doing more...., I am just keeping my word.
First Name: Henry
Last Name: Lee
Re: Helping a Friend with a Promise
Post by Henry K. Lee » Sat Oct 25, 2025 2:23 pm
It will have wing wings as well.
Will provide more as this project progresses.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Oct 25, 2025 7:04 pm
Nice work. Are they going to be polished when completed?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Oct 25, 2025 7:20 pm
To a mirror finish!
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Oct 25, 2025 11:21 pm
That is one of the most informative posts here and a long time not only did you show how but you included how and what you used to compete the project. I wonder where you found that cowl piece, did you make it or find a vendor. I have the same wood firewall and would like to add a form bent cowl as shown.
thank you for the post,
frontyboy
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 04, 2025 5:28 pm
Well finally finished up the truing of the billet on a vertical belt sander using 40 grit. I drill completely thru the stanchions and then TIG up the holes for a full depth thread.., old school. Now making windshield/wind-wing templets and setting the style as we agree on the final design. Next will post pictures on how to carve the billet the easy way.
Stay tuned for more magic.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 04, 2025 5:30 pm
Some added items......,
Firewall dishing for an overhead conversion! Lower floor board heat shields are a must!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 04, 2025 5:33 pm
Bucket seats are nice but they do not meet the stature requirements for modern old aged folks...., converting to a love seat design!
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Tue Nov 04, 2025 5:39 pm
That is very nice and creative work. Art
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Nov 04, 2025 6:19 pm
The Michelangelo of Model T art. :)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Nov 04, 2025 7:19 pm
Curiosity...
Is the aluminum piece on the cowl, tube or solid?
For the heat shields, did you use a bead roller or a press?
Is the seat center vertical piece aluminum or steel?
Vern (Vieux Carre)
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 04, 2025 7:26 pm
Billet T6061 aluminum (solid).
Galvanized sheetmetal formed on a box brake with 4,000 degree proof rock wool behind it.
Seat was supplied by customer (steel) just modifying for comfort.
Last Name: Hatch
Post by Dan Hatch » Wed Nov 05, 2025 7:33 am
Very well done Hank.
Reminds of some Herm’s post on engine work.
This what this Forum should be about. Learning how things are done.
Again, well done. Please continue doing this. Dan
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Nov 05, 2025 5:12 pm
The key in a good job is quality material, T6061 billet, good files and rasp. When ever you are working any soft material use canners wax by means of rubbing your file. They never plug and clean up easy. Watch your pressure when cutting on the strokes. I use lay out dye for a good contrast.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Nov 05, 2025 5:14 pm
I have been using the same files for over 12 years. After 2 cups of coffee this morning.., one is in the rough.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Nov 06, 2025 5:59 pm
Well both frames are in shape today. Did some shopping for peep mirror mounts and they all look like flimsy crap...., Soooo I started making dagger style.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 07, 2025 2:36 pm
So after all the rough in with a rasp file, I come back with a conventional double bastard and then down to a single bastard file. Then I start with 80 grit, 120 grit, 240 grit, 320 grit all dry. As you can see depending on the cloth wheel weave and jewelers rouge used will determine your sheen. We are going for a German Nickel appearance. Pretty close!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Nov 12, 2025 3:35 pm
All what is left for the windshield is upper and lower channels with retainers/cut and polish the glass. Started the pull back pleated seat wrap for back and cushions.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Nov 12, 2025 3:36 pm
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Nov 12, 2025 9:00 pm
Absolutely amazing craftsmanship my friend!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 14, 2025 5:40 pm
All what is left is polishing the edges of the wing wings and it is ready for collection. Will be back after painting to install the upholstery.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 14, 2025 5:42 pm
