Roof overhead
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Roof overhead
Post by Ralph F » Fri Dec 05, 2025 2:37 pm
I need to find some valves for a Roof Liberty Overhead. The valve deminsion are the following
Head diameter-1.685”
Stem diameter- .308
Length- 5.839
My other question is what the valve grind? Is the grind similar to what you would grind on model t
Fitz
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Roof overhead
Post by frontyboy » Sat Dec 06, 2025 12:24 am
I have a Roof 8 valve and I can drop a valve and check the degree of the valve face and the degree of the seat. If that would help you. My head is just sitting on the shelf ready to install on my engine when I get to it. Do you have an exhaust manifold, I may not use mine haven't made up my mind yet.
just sayin
frontyboy.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Re: Roof overhead
Post by AndreFordT » Sat Dec 06, 2025 4:56 am
The 16 valves Roof I have here takes standard model T valves, just not 8 but 16.
I don't know for the 8 valves Roof.
Andre
Belgium
Gary_in_MN
First Name: Gary
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster/ Depaul OHV
Re: Roof overhead
Post by Gary_in_MN » Sat Dec 06, 2025 7:37 am
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Re: Roof overhead
Post by tman1913 » Sat Dec 06, 2025 9:37 am
SBI has PDF,s you can download. You have some dimensions and should find something that will work. Nothing special about a valve angle grind.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Roof overhead
Post by Dan McEachern » Sat Dec 06, 2025 12:55 pm
Biggest issue will be finding an off the shelf exhaust valve with a stem that long. Many engines like small block Chevrolet have valve stems just over 5" long.
Chevrolet 216 qnd 235 ci engines had a long stem that can be cut down if the head diameters are close. Also at one time Egge Machine had valve blanks available. Shortening valve stems and turning down valve heads is something that you may have to do if you find a valve to modify.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Roof overhead
Post by Kevin Pharis » Sat Dec 06, 2025 3:24 pm
Manley Valve has a custom order option. Won’t be cheap, but they’ll be right
Re: Roof overhead
Post by Mark Gregush » Sat Dec 06, 2025 7:42 pm
If you can get ahold of an automotive engine valve catalog you could spend some time looking for something that matches. You could go with a larger diameter head and have it cut down along with longer stem.
