How to repair this
Dave1
Topic author - Posts: 130
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
How to repair this
My 27 touring has a crack / bend in the the lower section of the the front bow. Wondering is I should attempt to repair on the car?
I have a lathe so I could cut it off at the break and make a dowel to fit inside, then braze up the joint.
Anybody tried this repair?
Dave1
- Last Name: Eddie
Re: How to repair this
Posted a picture but it didn’t load ??
Most likely, the break occurred because the bow socket is rusted out from the inside. Maybe you can do the braze repair you suggest, but you're just as likely to find that there's not much left of the rest of the socket either. Hope not. Maybe the pictures will tell more.
Dave1
- Last Name: Eddie
Sure enough the PO had applied some weld to the thing sections of the bow tubing, along with some paint,… so it was fixed, Right?!!
Next step is to replace the bow, are these available from the vendors??
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Dave you kind of out of luck there no one offering new bows your stuck fixing it. I've repaired them by fitting a steel pipe and welding thru holes drilled thru the bow to a fix it to the pipe inside. It works pretty good as long as your bow is solid
Dave1
- Last Name: Eddie
Thanks Karl
browning
- Last Name: Kahle
- * REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
I would consider cutting a 3/8" or so steel dowel to the appropriate length and then wrapping it with fiberglass cloth into a tootsie roll that would just fit inside the broken section, wrapping tape around the break to prevent leakage and provide alignment and then drilling a hole above the repair and filling the socket with fiberglass resin, flooding the dowel and cloth. Repairing the hole should be easy after that.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Bows broken like that are an all to common occurrence.
The ends of the bows are solid castings or forgings that have a thin sheet metal formed tube slipped over them and fastened on.
To give strength to the thin tubes there is a tapered piece of wood slipped inside hopefully all the way to the solid end.
All of the rivets for the hinges and hardware go through the wood slipped in the bows so they may or may not need to be removed.
But there is a weak spot where the wood filler is not actually attached to the solid ends.
Move forward in time to today and add rust (promoted by wood holding moisture), stress cycling, some accidental damage and sometimes I am surprised any of the top bows have survived. On the cars that screw to the windshield posts ('23-'27) the stress on the top when the chassis twists is quite high.
They were never designed to be fixed and trying to weld thin rusted, fatigued, painted metal to a thick solid chunk is either difficult or impossible.
So what can you do:
1) Run topless
2) Take your chances trying to find better parts - This is tough since they stopped reproducing them years ago.
3) Try to do a butt weld joint that may or may not work and may or not hold up.
4) Try drilling and tapping a bolt into the end of the solid part to make a solid pin connection. Reassemble and tape the joint and fill the bottom of the bow with epoxy and filler strips. If done correctly it will hold for a while, not sure how long. I have seen others do it before.
5) Bite the bullet and disassemble the seam from the solid to the sleeve area and get to the stepped area. Make a new sheet metal tube end and a sheet metal reinforcement inner sleeve. Shorten the broken bow sleeve enough so that the whole assembly will return to being the correct length again. Fasten it all together with the new metal and reinforced repair joint. The reinforcement will be on the inside and not seen.
6) Make an sleeve to go over the outside of the area and live with it not looking original. It won't look right but can function well.
7) Something I have not thought of, or heard of, or done before.
And there is the top material that is supposed to secure it all to the car and won't help your repair efforts.
What you decide to do will depend on your luck finding a good part, budget, tools, and skills.
Mike
So what can you do:
1) Run topless
Mike
michaelb2296
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
There is someone who repairs these. John Boorinakis in California. I sent you his contact info.
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Does anyone have a link to Richard Eagle's posting of how he made new sockets.
I did a search but did not find it.
I think it was under a different subject may be something to do with his way of spending time?
Mike Silbert
- First Name: Mike
I think you are referring to this...
https://www.mtfca.com/discus/messages/7 ... 1509727571
It give a clear idea of what I was trying to describe about how they are built.
Richard Eagle was a prolific poster and always tinkering in the shop and with art.
6236 forum postings if you search
Too bad he passed in 2024.
Mike
Mike
varmint
- First Name: Vernon
- Last Name: Worley
I have had success with inserting a steel pipe piece and welding...this was on a different Ford and a more important part of the vehicle. It can be done.
Vern (Vieux Carre)
Shrshot
- First Name: Kent
- Last Name: Palazzo
- Board Member Since: 2024
If you have access to someone with a TIG welding machine that can be repaired on the car. If you were close I would do it for you. I have a Miller Sychro-Wave SD welder. TIG welding does not produce any spatter, so no worries to surrounding area. That's not a difficult repair in the right hands.
JRSpada4
- First Name: Jim
- Last Name: Spadafore
- * REQUIRED* Type and Year of Model Ts owned: 1925 Touring
I repaired one and the same spot by putting a piece of all-thread inside it and welding it back together. The all-thread core gives it support and something for the wire to bite to. Mine was also missing metal. The previous owner had “fixed” it by filling it with body filler. Once you clean it up with a grinder and some sandpaper, the repair disappears.
Age does this to steel bows. Rust eats inside to weaken it. After being sanded and repainted over the years the bow will break in time. Use a piece of thick wall EMT electrical conduit tubing inside the bow. Some type of steel reinforcement that’s pretty stable will do too if you don’t have steel tubing. Run the reinforcement in both directions as far as you can get it. If you try to weld or stitch it back together the metal may not be strong or good enough to hold the seam together. You may have to use some hose clamps to squeeze it together and then use steel pop rivet to get the seam together. Depends on how stable the inside of the bow is.
