How to repair this
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
How to repair this
Post by Dave1 » Thu Feb 12, 2026 1:55 pm
My 27 touring has a crack / bend in the the lower section of the the front bow. Wondering is I should attempt to repair on the car?
I have a lathe so I could cut it off at the break and make a dowel to fit inside, then braze up the joint.
Anybody tried this repair?
Dave1
Last Name: Eddie
Re: How to repair this
Post by Dave1 » Thu Feb 12, 2026 2:01 pm
Posted a picture but it didn’t load ??
Post by Jerry VanOoteghem » Thu Feb 12, 2026 2:13 pm
Most likely, the break occurred because the bow socket is rusted out from the inside. Maybe you can do the braze repair you suggest, but you're just as likely to find that there's not much left of the rest of the socket either. Hope not. Maybe the pictures will tell more.
Dave1
Last Name: Eddie
Post by Dave1 » Thu Feb 12, 2026 3:23 pm
Dave1
Last Name: Eddie
Post by Dave1 » Thu Feb 12, 2026 3:38 pm
Sure enough the PO had applied some weld to the thing sections of the bow tubing, along with some paint,… so it was fixed, Right?!!
Next step is to replace the bow, are these available from the vendors??
Dave1
Last Name: Eddie
Post by Dave1 » Thu Feb 12, 2026 3:47 pm
Next step is to replace the bow, are these available from the vendors??IMG_4318.jpegI
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Thu Feb 12, 2026 4:24 pm
Next step is to replace the bow, are these available from the vendors??IMG_4318.jpegIMG_4318.jpegIMG_4318.jpeg
Dave you kind of out of luck there no one offering new bows your stuck fixing it. I've repaired them by fitting a steel pipe and welding thru holes drilled thru the bow to a fix it to the pipe inside. It works pretty good as long as your bow is solid
Dave1
Last Name: Eddie
Post by Dave1 » Thu Feb 12, 2026 4:42 pm
Thanks Karl
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Post by browning » Thu Feb 12, 2026 4:57 pm
I would consider cutting a 3/8" or so steel dowel to the appropriate length and then wrapping it with fiberglass cloth into a tootsie roll that would just fit inside the broken section, wrapping tape around the break to prevent leakage and provide alignment and then drilling a hole above the repair and filling the socket with fiberglass resin, flooding the dowel and cloth. Repairing the hole should be easy after that.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Feb 12, 2026 8:33 pm
Bows broken like that are an all to common occurrence.
The ends of the bows are solid castings or forgings that have a thin sheet metal formed tube slipped over them and fastened on.
To give strength to the thin tubes there is a tapered piece of wood slipped inside hopefully all the way to the solid end.
All of the rivets for the hinges and hardware go through the wood slipped in the bows so they may or may not need to be removed.
But there is a weak spot where the wood filler is not actually attached to the solid ends.
Move forward in time to today and add rust (promoted by wood holding moisture), stress cycling, some accidental damage and sometimes I am surprised any of the top bows have survived. On the cars that screw to the windshield posts ('23-'27) the stress on the top when the chassis twists is quite high.
They were never designed to be fixed and trying to weld thin rusted, fatigued, painted metal to a thick solid chunk is either difficult or impossible.
So what can you do:
1) Run topless
2) Take your chances trying to find better parts - This is tough since they stopped reproducing them years ago.
3) Try to do a butt weld joint that may or may not work and may or not hold up.
4) Try drilling and tapping a bolt into the end of the solid part to make a solid pin connection. Reassemble and tape the joint and fill the bottom of the bow with epoxy and filler strips. If done correctly it will hold for a while, not sure how long. I have seen others do it before.
5) Bite the bullet and disassemble the seam from the solid to the sleeve area and get to the stepped area. Make a new sheet metal tube end and a sheet metal reinforcement inner sleeve. Shorten the broken bow sleeve enough so that the whole assembly will return to being the correct length again. Fasten it all together with the new metal and reinforced repair joint. The reinforcement will be on the inside and not seen.
6) Make an sleeve to go over the outside of the area and live with it not looking original. It won't look right but can function well.
7) Something I have not thought of, or heard of, or done before.
And there is the top material that is supposed to secure it all to the car and won't help your repair efforts.
What you decide to do will depend on your luck finding a good part, budget, tools, and skills.
Mike
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Post by michaelb2296 » Fri Feb 13, 2026 8:57 am
There is someone who repairs these. John Boorinakis in California. I sent you his contact info.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Fri Feb 13, 2026 10:00 am
Does anyone have a link to Richard Eagle's posting of how he made new sockets.
I did a search but did not find it.
I think it was under a different subject may be something to do with his way of spending time?
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Fri Feb 13, 2026 11:46 am
I think you are referring to this...
https://www.mtfca.com/discus/messages/7 ... 1509727571
It give a clear idea of what I was trying to describe about how they are built.
Richard Eagle was a prolific poster and always tinkering in the shop and with art.
6236 forum postings if you search
Too bad he passed in 2024.
Mike
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Feb 13, 2026 12:50 pm
I have had success with inserting a steel pipe piece and welding...this was on a different Ford and a more important part of the vehicle. It can be done.
Vern (Vieux Carre)
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Fri Feb 13, 2026 2:18 pm
If you have access to someone with a TIG welding machine that can be repaired on the car. If you were close I would do it for you. I have a Miller Sychro-Wave SD welder. TIG welding does not produce any spatter, so no worries to surrounding area. That's not a difficult repair in the right hands.
