I need help from the early T owners!
Belliott3
Topic author - Posts: 366
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
I'm in the process of putting my 1910 Touring back together and I'm wondering where to find the small studs that attach to the buggy rail. There are several small holes in my rail that these studs go into in order to attach the top to instead of Murphy fasteners. I'm not exactly sure what the correct terminology is but does anyone make these studs? I can't seem to find them in any of the supply catalogs. Any recommendations would be greatly appreciated!
Les Schubert
- First Name: Les
- Last Name: Schubert
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Re: I need help from the early T owners!
How many no you need?
Belliott3
- First Name: Bill
Steve, I do believe those are them! I counted the holes in my buggy rail and I'll need ten total. Is there a nut that holds it in place, since my holes go all the way through the rail?
The ones I have were machined by Otis Clinton a long, long time ago. I'll bow out to Kim D. if he can assist you first, if not drop me a note. My friend's '10 was here a month ago but I didn't take notice of those on the buggy rail - Kim might recall these studs utilizing a nut of some type.
KimDobbins
- First Name: Kim
Steve, I don't have that many, I know Otis made nice ones. They push through the buggy rail and I think are then peened. I'll check tomorrow.
Dale_mcm
- First Name: Dale
- Last Name: McMurry
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
My 1910 stud has threads. The stud is brass and there is a steel funnel type washer on it that seats up against the steel buggy rail.
KimDobbins
- First Name: Kim
The ones on my 1910 are not threaded, just pushed through the rail and peened.
KimDobbins
- First Name: Kim
Belliott3
- First Name: Bill
Thanks for all the help and input; as always, it's much appreciated! And thanks to Steve for parting with some of your stash!
