I need help from the early T owners!
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Sat Aug 03, 2019 7:41 am
I'm in the process of putting my 1910 Touring back together and I'm wondering where to find the small studs that attach to the buggy rail. There are several small holes in my rail that these studs go into in order to attach the top to instead of Murphy fasteners. I'm not exactly sure what the correct terminology is but does anyone make these studs? I can't seem to find them in any of the supply catalogs. Any recommendations would be greatly appreciated!
Les Schubert
First Name: Les
Last Name: Schubert
Re: I need help from the early T owners!
Post by Les Schubert » Sat Aug 03, 2019 10:37 am
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sat Aug 03, 2019 5:49 pm
How many no you need?
Post by RajoRacer » Sat Aug 03, 2019 8:10 pm
Are you referring to these ?
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Sat Aug 03, 2019 8:36 pm
Steve, I do believe those are them! I counted the holes in my buggy rail and I'll need ten total. Is there a nut that holds it in place, since my holes go all the way through the rail?
Post by RajoRacer » Sat Aug 03, 2019 9:41 pm
The ones I have were machined by Otis Clinton a long, long time ago. I'll bow out to Kim D. if he can assist you first, if not drop me a note. My friend's '10 was here a month ago but I didn't take notice of those on the buggy rail - Kim might recall these studs utilizing a nut of some type.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sun Aug 04, 2019 2:49 am
Steve, I don't have that many, I know Otis made nice ones. They push through the buggy rail and I think are then peened. I'll check tomorrow.
Dale_mcm
First Name: Dale
Last Name: McMurry
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
Post by Dale_mcm » Sun Aug 04, 2019 11:30 pm
My 1910 stud has threads. The stud is brass and there is a steel funnel type washer on it that seats up against the steel buggy rail.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Mon Aug 05, 2019 11:19 pm
The ones on my 1910 are not threaded, just pushed through the rail and peened.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Mon Aug 05, 2019 11:25 pm
1910 buggy rail
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Tue Aug 06, 2019 6:57 am
Thanks for all the help and input; as always, it's much appreciated! And thanks to Steve for parting with some of your stash!
