Best, Easiest standard transmission conversion for 27 T
Michael Davis
First Name: Michael
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1923 Center door
Post by Michael Davis » Mon Sep 09, 2019 4:53 pm
Hey guys What would you recommend for the conversion of a floor 3 speed transmission to put behind a 27 T engine.
Thanks Mike
Re: Best, Easiest standard transmission conversion for 27 T
Post by Wayne Sheldon » Mon Sep 09, 2019 6:16 pm
Talk to Mark F at Model T Haven, and bring a fat checkbook. I know he had a Himico transmission/engine made back in the day for a model T. I don't know if he still has it?
Chevrolet transmissions can be adapted to fit in behind the model T's planetary more easily than most others because the U-joint and four-bolt bell coupler is fairly compatible with the model T's. I have heard (but not seen) of Chevy transmissions from the late '30s being used because they have syncromesh on second and high gears.
I have never considered that a very good arrangement because you still have to use the model T's clutch which I love in a model T, however it is problematic for pure clutch usage (removing the bands would help with the use of the clutch?). Personally, I like using a model T planetary with a Warford or Muncie behind!
A full clutch, flywheel, and transmission conversion properly done would cost a BUNCH! (Don't forget oiling!)
jsaylor
Last Name: Saylor
Post by jsaylor » Mon Sep 09, 2019 6:55 pm
Easiest and the most sanitary and still look original would be a Ruckstell. Easy to shift and you effectively have 4 speeds forward and 2 reverse. Add a foot throttle and you can shift all 4 with ease. But with any auxiliary, you will need good brakes on the rear axle.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Sep 09, 2019 7:14 pm
Mike
In my case I got really lucky and found a original era bolt in transmission conversion that replaced the original transmission and hogshead with a 3 speed sliding version built in Canada
Post by Allan » Mon Sep 09, 2019 7:26 pm
In my opinion, there is not an easier to fit, more satisfactory result and wonderfully easily operated transmission them a Layne Warford style auxilliary gearbox. These give excellent results, and you can still drive the T exactly as is standard if that is what you like to do.
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Mon Sep 09, 2019 8:02 pm
Why???? :?:
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Mon Sep 09, 2019 8:15 pm
The simplest, cheapest and most trouble free conversion would be to swap your Model T for a '27 Cheby. :roll:
"Get a horse !"
Post by Mark Gregush » Mon Sep 09, 2019 8:41 pm
None in my OP are EASY to install, but something like a Jumbo that has 3 speeds and reverse. You however would still be working with a wet disk clutch even if you removed the low and reverse bands. Ford may have kept the disk clutch in the early A's, but it was dry disk.
Post by Allan » Tue Sep 10, 2019 6:12 am
Rich, whoever heard of a trouble free 27 Chebby?
The wet clutch is not a problem to Layne style Warford. You just haul on the lever and it will change without using the clutch. A foot throttle helps to match the engine revs, but is not essential.
Why? When I built my extended chassis 1917 shooting brake which can carry 8 adults, it features a rather heavy solid timber body. The Layne gearbox allows me to get off the mark easily, with no lugging in top gear. It drives just like a 3 speed. When it is rolling under favourable conditions, it can certainly take advantage of the overdrive gear.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Sep 10, 2019 10:38 am
Allan, I didn't mean the Cheby would be trouble-free. Just the "conversion" ! :lol:
"Get a horse !"
Post by Original Smith » Tue Sep 10, 2019 10:53 am
If you knew the trouble that would cause you, you might want to consider leaving it alone. Been there, done that.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Sep 10, 2019 2:00 pm
Now IF he was looking for a 4 speed or a automatic then I could offer some true insight into some solutions. A Volvo 4 speed can be bolted in the same space that a Warford takes. 4 speed all synchro!! Or 4 or 5 speed from a Mustang 2. Drive line gets a bit more complicated
Michael Davis
First Name: Michael
Last Name: Davis
Post by Michael Davis » Tue Sep 10, 2019 7:44 pm
WOW Thanks everyone. I will just leave it alone.
Mike
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Sep 10, 2019 8:10 pm
Complicated Les says...., Les, THERAPY!!
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Sep 10, 2019 8:15 pm
Absolutely right Hank!!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Sep 10, 2019 8:16 pm
FUN, FUN, FUN, Les! You started this with me.., Dr Les, Therapist!
Hank
tdumas
First Name: Ted
Last Name: Dumas
* REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Post by tdumas » Tue Sep 10, 2019 8:16 pm
Hank,
You had some Chevrolet transmissions for sale that were modified to fit the T driveline. Maybe he could use one.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Sep 10, 2019 8:20 pm
Ted,
You have to do modifications to the torque tube, install accessory brakes, etc. Works excellent but comes with $$$$ spent and time. Just saying. Thank You though.
Hank
thom
First Name: Tommy
Last Name: Coffey
Post by thom » Tue Sep 10, 2019 8:31 pm
Good decision to leave it alone, Mike. Stick to your decision. You'll be happier in the long run.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Sep 10, 2019 8:49 pm
Nice looking adapter Hank!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Sep 11, 2019 6:49 pm
Maybe this
