Ideal crankshaft radius?
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Tue Oct 01, 2019 8:57 am
What is the preferred radius of a T crankshaft? Thanks for your time and help. Bob 903 824 1949
Re: Ideal crankshaft radius?
Post by Mark Gregush » Tue Oct 01, 2019 9:25 am
I am pretty darn sure it is 1/8".
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Tue Oct 01, 2019 10:09 am
Hmmm. Interesting answer - probably what the questioner wanted, but I was thinking 'What's half the stroke? Ah yes, 2"'
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Tue Oct 01, 2019 10:25 am
Chris,
I was thinking exactly the same thing as you, 2".
Post by DanTreace » Tue Oct 01, 2019 11:44 am
Earlier post with factory dimension stated:
http://www.mtfca.com/discus/messages/29 ... 1201460648
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Wed Oct 02, 2019 11:46 am
From the research in building the six 1914 replicas, the radius between the bearing surface and the side of the crank is specified as 0.125”.
Tony Bowker
La Mesa, California
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Wed Oct 02, 2019 3:23 pm
It has an 1/8th, .125 inch Radius. No bigger, or smaller. Rods, and mains should be cut that Diameter, also, or you will have a mating problem.
A 2" Radius, should be closest to a 15" Diameter crank.
Her.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Sun Oct 06, 2019 7:38 pm
Would the Model A & B crankshaft also be 1/8"?
