Ideal crankshaft radius?
BobShirleyAtlantaTx
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
What is the preferred radius of a T crankshaft? Thanks for your time and help. Bob 903 824 1949
Re: Ideal crankshaft radius?
I am pretty darn sure it is 1/8".
Chris Barker
- First Name: Chris
- Last Name: Barker
Hmmm. Interesting answer - probably what the questioner wanted, but I was thinking 'What's half the stroke? Ah yes, 2"'
HPetrino
- First Name: Henry
- Last Name: Petrino
Chris,
I was thinking exactly the same thing as you, 2".
TonyB
- First Name: Tony
- Last Name: Bowker
From the research in building the six 1914 replicas, the radius between the bearing surface and the side of the crank is specified as 0.125”.
Tony Bowker
La Mesa, California
La Mesa, California
Kohnke Rebabbitting
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
It has an 1/8th, .125 inch Radius. No bigger, or smaller. Rods, and mains should be cut that Diameter, also, or you will have a mating problem.BobShirleyAtlantaTx wrote: ↑Tue Oct 01, 2019 8:57 amWhat is the preferred radius of a T crankshaft? Thanks for your time and help. Bob 903 824 1949
A 2" Radius, should be closest to a 15" Diameter crank.
Her.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Would the Model A & B crankshaft also be 1/8"?
