Keep on trucking
Keep on trucking
Post by Dollisdad » Fri Nov 01, 2019 9:42 pm
Re: Keep on trucking
Post by Dollisdad » Fri Nov 01, 2019 9:44 pm
Post by Dollisdad » Fri Nov 01, 2019 9:48 pm
Ken Lefeber
First Name: Ken
Last Name: Lefeber
Post by Ken Lefeber » Fri Nov 01, 2019 11:32 pm
What's on the tires on the 2nd picture from the top?
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Post by kmatt » Fri Nov 01, 2019 11:41 pm
Those are air cushioned solid rubber tires. The air cushion comes from the holes in the tires you see in the picture as black dots. No flat tires to fix was the marking they were sold by.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Sat Nov 02, 2019 3:12 am
The Holmes Bread truck in the third picture may not be a Ford. Both the front and the rear axles are on two springs, all of the others are on the expected Ford single transverse spring, at least in front.
Eric
Kerry
Last Name: van Ekeren
Post by Kerry » Sat Nov 02, 2019 3:41 am
It looks T to me, just a spring kit of some sort fitted.
