Mysterious Size of Woodruff Key for Steering Gear Ball Arm Part#3548 Question?
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Mon Jan 28, 2019 12:36 am
I am helping a friend with there Model T and discovered that the steering gear ball had the wrong key and there was play. Since that is the only part I need I figured I could go to the hardware store. So I looked up the size and was surprised that I came up with two dead ends.
#1 Steve Jelf's world famous reference just has "???" :o see: http://www.mtfca.com/discus/messages/82 ... 904367.pdf
#2 This thread on the MTFCA from last year left me with more questions than answers:
http://www.mtfca.com/discus/messages/82 ... 1525568272
Is the Woodruff Key for Steering Gear Ball Arm Part#3548 just a standard key or something else?
Thanks,
Matt
Re: Mysterious Size of Woodruff Key for Steering Gear Ball Arm Part#3548 Question?
Post by DanTreace » Mon Jan 28, 2019 9:29 am
The Steering Gear Ball Arm Woodruff Key, p/n 3548, is 1/4" wide x 7/8" long x 11/32" tall.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Jan 28, 2019 9:38 am
I would say the proper torque on the pittman arm nut, locking the tapered fit together is as or more important than the fit of the woodruff key.
Just sayin... ;)
Post by DanTreace » Mon Jan 28, 2019 9:46 am
Yep, that too, and the cotter pin on that castle nut ;)
rondupree
First Name: Ronald
Last Name: Dupree
Post by rondupree » Mon Jan 28, 2019 2:22 pm
The problem is that Ford used a big key in a small diameter shaft. If you try to use a standard woodruff key, it sticks up too high and you cannot tighten the pitman arm on the steering shaft. The 'special' Ford woodruff key has been ground to reduce its height by flattening the rounded side. This allows the pitman arm to seat properly on the shaft....Don't ask me how I know..
Ron Dupree
Ron Dupree
Post by DanTreace » Mon Jan 28, 2019 2:31 pm
Thanks Ron
Your important tip is correct.
Should have posted the sketch.
Many 'hardware store' replacements for Ford parts don't always fit or function like the actual part. :|
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Tue Jan 29, 2019 11:57 am
Wow! You guys have all been very helpful! Awesome sketch Don!
I plan to go to the hardware store and buy a 1/4" x 7/8". Then I will then grind it to size.
Thanks so much!
Matt
