1909-10 sidelight brackets
Alex Dragone
First Name: Alex
Last Name: Dragone
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Post by Alex Dragone » Wed Dec 11, 2019 1:17 pm
I am having a discussion with a friend and we would like to know if the 1909-10 brackets were originally made out of cast brass or pressed steel and brass plated. I have seen them both ways. It seems to me that originally they were brass plated steel. Can anyone shed light on this?
pete eastwood
First Name: Pete
Last Name: Eastwood
Re: 1909-10 sidelight brackets
Post by pete eastwood » Wed Dec 11, 2019 2:08 pm
Pressed steel & brass plated .
Post by Wayne Sheldon » Wed Dec 11, 2019 6:22 pm
Peter E would KNOW !
Larry
Last Name: Gresh
Post by Larry » Wed Dec 11, 2019 8:16 pm
The side light brackets were pressed steel and brass plated as were the fire wall riser to windshield brackets. Tail light bracket was cast steel and brass plated as well.
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Thu Dec 12, 2019 1:46 am
Steel and brass plated. Many other parts on the 09/10 Models were steel and bras plated including the emergency brake lever.
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Thu Dec 12, 2019 5:46 am
The spark and throttle rods and hand crank were also brass plated steel.
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Thu Dec 12, 2019 8:16 am
Alex: I cast them in Yellow brass because of the marginal quality of today's brass plating. Originals are heavy brass plated that can be repeatedly polished without wiping the brass off. You can lacquer coat these, but this is temporary protection and will rapidly tarnish under the lacquer. Some have cautioned that cast brass is weaker and therefore prone to a failure. This could be true if your casting alloy is junk, or if you are trying to use this bracket to jack up the car. You will not bend or break these parts by accidentally bumping them.
Regards,
Scott
