Livingston radiator
rnkugel
First Name: Reuben
Last Name: Kugel
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Livingston radiator
Post by rnkugel » Wed Feb 06, 2019 3:59 pm
Trying get an estimate on the year of my Livingston radiator. Any info would be appreciated.
1915 Touring
1926 RAJO Speedster
Re: Livingston radiator
Post by Mark Gregush » Wed Feb 06, 2019 5:52 pm
Ether someone did a fantastic restoration on it or it's a more modern reproduction. If it is a repo, I wonder if that little brass button next to the data plate is the year, 1967.
Post by DanTreace » Wed Feb 06, 2019 8:23 pm
Beautiful speedster you have! And that 'V' radiator looks terrific too.
Original Livingston's normally exhibit the tapered front tank and normally an oval emblem on the face of that tank.
1915
Ratfink56
First Name: Duane
Last Name: Epper
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring
Post by Ratfink56 » Thu Feb 07, 2019 11:37 pm
They had a couple of tags on the early ones.
Ratfink56
First Name: Duane
Last Name: Epper
Post by Ratfink56 » Thu Feb 07, 2019 11:39 pm
Post by Allan » Sat Feb 09, 2019 6:04 pm
Rueben, your radiator has to be the most attractive aftermarket radiator I have seen. The lines are reminiscent of those on early Benz cars. The rounded top corners really make it a pleasing design.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun Feb 10, 2019 2:39 pm
I suggest that your radiator is teens but the shell is modern.
Mine needs a new shell. Oval spot is where the tag was soldered on.
doodlebugt
First Name: Bruce
Last Name: Csorba
* REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Post by doodlebugt » Sun Feb 10, 2019 6:49 pm
My Livingston is a probably an early repro from the 70s?
Has Ford type core.
15 4 springer
15 4 springer
BTW Layden, your boxes aren't stacking well. I can help by getting rid of that awkward heavy lump on your floor :-)
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Feb 15, 2019 1:48 pm
Bruce,
Don't be shy. Make an offer on the radiator and it might yours!
Anyone else interested can also contact me.
001 email address.jpg (64.51 KiB) Viewed 5322 times
