Livingston radiator
rnkugel
Topic author - Posts: 43
- First Name: Reuben
- Last Name: Kugel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Livingston radiator
Trying get an estimate on the year of my Livingston radiator. Any info would be appreciated.
1915 Touring
1926 RAJO Speedster
1926 RAJO Speedster
Re: Livingston radiator
Ether someone did a fantastic restoration on it or it's a more modern reproduction. If it is a repo, I wonder if that little brass button next to the data plate is the year, 1967.
Beautiful speedster you have! And that 'V' radiator looks terrific too.
Original Livingston's normally exhibit the tapered front tank and normally an oval emblem on the face of that tank.
1915
1915
Ratfink56
- First Name: Duane
- Last Name: Epper
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring
They had a couple of tags on the early ones.
Rueben, your radiator has to be the most attractive aftermarket radiator I have seen. The lines are reminiscent of those on early Benz cars. The rounded top corners really make it a pleasing design.
Layden Butler
- First Name: Layden
- Last Name: Butler
I suggest that your radiator is teens but the shell is modern.
Mine needs a new shell. Oval spot is where the tag was soldered on.
doodlebugt
- First Name: Bruce
- Last Name: Csorba
- * REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
My Livingston is a probably an early repro from the 70s?
Has Ford type core. BTW Layden, your boxes aren't stacking well. I can help by getting rid of that awkward heavy lump on your floor
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
Layden Butler
- Last Name: Butler
Bruce,
Don't be shy. Make an offer on the radiator and it might yours!
Anyone else interested can also contact me.
- Attachments
- 001 email address.jpg (64.51 KiB) Viewed 5449 times
