PARTS OF MODEL T FORDS USED FOR OTHER THINGS,
RichardG
Topic author - Posts: 353
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
GOING BACK 50---60- YEARS THERE WAS A GUY I KNEW UP IN GAYSVILL VERMONT, HE BUILT A WIND POWER BATTERY CHARGER OUT OF A MODEL T BLOCK, HE CUT IT DOWN AND MOUNTED IT UP SIDE DOWN ON A PLAT FORM BOLTED TO THE BRAKE DRUM OF HALF THE T REAR END, ,IT HAD A THREE BLADE PROP , USED THE MAG TO CHARGE THE BATTERY'S, THIS GETUP WORKED REAL GOOD FOR YEARS, HE USED THE HEAD LIGHTS FOR OUT SIDE, HIS HOME WAS ON A GOOD HILL AND A BROOK RUN BY, HE HAD EVERY THING NEEDED TO LIVE , PLENTY OF VENISON, ECT. I HAVE A 1925 T ENGINE THAT'S USED FOR A SAW RIG, IVE SEEN THE FRAME AND RUNNING GEAR USED FOR A HAY TRAILER, I WORKED ONE TIME ON A T ENGINE THAT WAS USED ON A ROPE TOW FOR PULLING SKIERS UP THE HILL. WHAT HAVEN'T THESE FORD PARTS BEEN USED FOR, NOW SOME OF THESE PARTS ARE GOING BACK INTO CARS, THEY WERE CALLED THE UNIVERSAL CAR, THAT FIT IT TO A --T--.
2nighthawks
- First Name: Harold
- Last Name: Schwendeman
Re: PARTS OF MODEL T FORDS USED FOR OTHER THINGS,
In the years not too long after the Model T "era", magazines like Popular Mechanics and Mechanics Illustrated, quite often had articles about practical uses for parts from Model T's, or, practical things that could be built that utilized Model T parts. Especially during the depression I think, because of two reasons; people had no money to buy a lot of the things that could be built by the "home mechanic" such as tools and such, and the other reason that there were so many Model T's laying around in fields, farms, etc, just rusting away. They were considered to be "old-fashioned" junk, even if some of them could be fairly easily and inexpensively put back into running condition.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Our local bakery had a bread loaf slicing machine that used a T crankshaft and 4 connecting rods to provide the up and down motion to the slicing knives.
Bill Robinson
- First Name: Bill
- Last Name: Robinson
I raise a few cattle. About 25 years ago I had a electric fence charger bit the dust. There was an old guy near Flintville who repaired chargers out in his barn. I delivered my charger to him driving my '26 Pickup. The first thing he did was take me over to his personal charger that he used on his own fence. Inside a homemade wooden box was a 12v battery driving a small electric motor-------which turned rotated an old roller in a Ford timer--------which in turn actuated a Ford wooden coil--------which in turn shocked the pee-rooney out of any cow that got up against his barbed wire fence.
Ruxstel24
- Last Name: Hanlon
I have a bottle capper with a T steering wheel on it.
I imagine most have seen a jackstand from axle housings.
Mike Robinson
- First Name: Michael
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster 1914 Speedster 1925 Touring 1926 roadster pickup
A hose reel can be made out of an old T or A wheel when it is damaged beyond use.
StanHowe
- First Name: Stan
- Last Name: Howe
I have a metal lathe made with a lot of Model T parts. It is very cool. I also have wall mounted drill press made from a T starter.
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
I have a haymow rope pulley made from a Hayes 30 x 3 1/2 demountable rim. The frame is made from wood with a hook to hang it in the barn with and has a large manila rope to lift the hay with. The rim is in excellent condition, but is missing a lug. I originally bought it at a flea market for the rim (easy fix), but I decided it was just too cool to take apart. Dave
1925 mostly original coupe.
Grady Puryear
- First Name: Grady L
- Last Name: Puryear
Both of my Grand Daddy's were old time Country Blacksmiths, we never did have electricity, so they flame welded, and it worked as good or better than an electric machine. I think everything on both places were made out of old T parts, both used T axles to make Spurs, they swore by the steel in them. T's were still fairly new then, so axles were reused, and sometimes hard to come by. They had a particular ring to them, I still have a pair my Paternal Grand Daddy made me, as new looking as ever. Trailers were all made out of T's, easy to do,just strip one down, take the engine out, make a simple hitch and you were in business.
- Last Name: Hatch
Find a Lejay Electric manual. You will see a lot of T parts repurposed in one of them.
- First Name: Adrian
- Last Name: Whiteman
An idler pully for a machine-ee-thingh
D Stroud
- Last Name: Stroud
I also have an implement seat mounted on a T axle housing half for a stool. No, I didn't make it, I found it at a flea market.
Dave
got10carz
- Last Name: Meixner
T frame rails welded together to hold up the loft in my shed.
got10carz
T running boards make steps to get to loft.
WayneJ
- Last Name: Jorgensen
From a previous forum post, here is a band saw, made from ….
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
RichardG
WAYNE, YOU GET THE BLUE STAR ON YOUR FORHEAD, THAT SAW IS SUPER, THANK YOU ALL FOR SHARING .LOOKS LIKE T THING WILL BE AROUND FOR ANOTHER HUNDRED YEARS.AND THEN SOME.
tinman080
- First Name: gary
- Last Name: hammond
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster
Replica car builders use a few T parts too..
''Just Passin' Thru.....Slowly!
Bill Robinson
- First Name: Bill
A home-made Father's Day gift from my son a few years ago. It really draws a lot of attention from visitors to my shop.
- First Name: Dennis
- Last Name: Seth
Taken from past posts I do not own these items.
- Attachments
- C.jpg (1.48 KiB) Viewed 9075 times
Mighty1924
- First Name: Rick
- Last Name: Shaw
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Winter time projects
Shelf from radiator shell
T Wheel table
Bench with running board in back
We use the table and bench on our patio.
T Wheel table
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Back when I first became enamored of the Model T Ford, before the demise of the forty acre farm (circa 1962) it seemed nearly every farmstead in our corner of southeast Idaho had one of these one-row spud diggers in their bone pile of discarded machinery. Now, like the small farm, they have disappeared along with the abundance of rust and really good junk we used to find in that period. This one has been elevated to relic status, adorning the owner’s mailbox location.
I’m pretty sure there’s an interesting story about them I never bothered to learn. There were so many of them it suggests they were the product of a cottage industry rather than the result of individual tinkerers. They could be a reasonable source of a few internal parts if your rear axle needed attention. I’d guess their working heyday would have run from the mid-1930s through the end of WW II, maybe as late as the mid-1950s. They were horse-drawn implements converted to tractor PTO power by virtue of the adapted Model T drive train. Most (like this one) were mated to three speed transmissions from Chevrolets or other small cars.
- Attachments
- CD20FBC8-9E43-4E35-B7FF-7E203397874A.jpeg (40.62 KiB) Viewed 8796 times
"Get a horse !"
halftracknut
- First Name: randy
- Last Name: lee
- * REQUIRED* Type and Year of Model Ts owned: 1926 pickup
RichardG
BILL ROBINSON--I CAN SEE WHY, AND BEING MADE BY YOUR SON MAKES IT VERY SPECIAL INDEED, BOY THIS HAS BEEN NEAT TO SEE THIS THINGS THAT WERE ONCE PART OF A FAMILY CAR, THINK OF IF EACH PART COULD SAY WHERE IS BEEN..
