26 27 Fordor body bracket questions
Tracer
First Name: Andrew
Last Name: Webb
* REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
Post by Tracer » Thu Apr 30, 2020 10:58 pm
Hi All
I am in the process of putting my Fordor body together and have the following questions please.
Question 1 From the attached pictures taken from Ray Elkins 2009 restoration I need the dimensions of the brackets that are just flat sheet as pictured 5 in total 2 are the same as each other. Also the location of these would be help too please.
Question 2 Does anybody know the location of these triangular shaped brackets. The ones with the curve.
Question 3. Are these other triangular brackets for a Fordor ? I cannot see them in the group of brackets that Ray Elkins posted in 2009.
Thank you
Andrew Webb
Tracer
First Name: Andrew
Last Name: Webb
Re: 26 27 Fordor body bracket questions
Post by Tracer » Thu Apr 30, 2020 10:59 pm
The brackets I need the Dimensions and location please
Tracer
First Name: Andrew
Last Name: Webb
Post by Tracer » Thu Apr 30, 2020 11:02 pm
Also the location of these brackets too
Post by Mark Gregush » Fri May 01, 2020 10:39 am
Suggestion, put the brackets you have questions about on contrasting background, lay them out and number them. Might be easier for people that would know to say bracket No X goes in this location. I looked in the body parts catalog but the only wood diagram leave something to be desired re what brackets go where. There is a hint but not much as some are only partly visible and others are not shown.
John Page
Last Name: Page
Board Member Since: 2010
Post by John Page » Fri May 01, 2020 3:46 pm
Hello Andrew,
A very good suggestion from Mark.
If Don Booth is watching this thread I am sure he would be able to help as well. He has certainly seen enough of these later Fordor's.
Not sure if you will gain much from these two links to Don's past work.
Best regards, John Page, Australia.
http://www.mtfca.com/discus/messages/59 ... 1482422995
http://www.mtfca.com/discus/messages/33 ... 1388852083
John Page
Last Name: Page
Post by John Page » Fri May 01, 2020 6:34 pm
Have just done some more digging.
If you follow this thread down there are images that Ray posted that might help.
http://www.mtfca.com/discus/messages/80257/87573.html
Tracer
First Name: Andrew
Last Name: Webb
Post by Tracer » Sat May 02, 2020 8:31 am
Thanks John and Mark
I have labelled the photos now
#1 looking for the location of this one. It’s a pair and I assume a corner brace
#2 not sure what these ones are
#3,4 these are not my pictures and I am missing these 5 brackets as circled in red 2 are a pair and am looking for dimensions and locations
Thank you
John Page
Last Name: Page
Post by John Page » Sat May 02, 2020 4:34 pm
This image might be a little clearer. J.P.
Tracer
First Name: Andrew
Last Name: Webb
Post by Tracer » Wed May 13, 2020 5:00 am
Just putting it back to the top please
FordorGalore
First Name: fore
Last Name: door
* REQUIRED* Type and Year of Model Ts owned: 1922 centerdoor 1927 fordor 1916 centerdoor
Post by FordorGalore » Wed May 13, 2020 7:11 am
Picture 1 that bracket goes on the main base of the car. Its a corner bracket for the cross-brace.
Picture 3 are the brackets for the main base that attaches the floorboard support (at both ends) between the battery access and the passenger side
of the floorboards.
The very top picture of the thread is the cosmetic plates that covers the wood in the very lower rear of the rear quarter windows.
You also have the C and D pillar supports that to connect to the main base frame on the inside of the bottoms of the pillars.
I can answer just about any other questions you may have if you want to PM me your email or phone number. Feel free to do so...
FordorGalore
First Name: fore
Last Name: door
Post by FordorGalore » Wed May 13, 2020 7:50 am
All main frame corner brackets mount on the underside on the main wood base frame.
Tracer
First Name: Andrew
Last Name: Webb
Post by Tracer » Wed May 13, 2020 11:36 pm
Thank you Don this information is very helpful
