24 tt closed cab top
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Wed Jan 29, 2020 10:15 pm
I am going to be putting a top wood and covering on a closed cab soon. The roof is mostly missing except a few sticks of wood. Does anyone have a plan or pictures of one complete? Both inside and out would be a great help. Thanks
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Re: 24 tt closed cab top
Post by Nunsio1 » Fri Jan 31, 2020 8:21 am
I have a 24 C cab with a wood roof, tried kits but they didn’t fit, made it from scratch. Covered it with convertible top material. Have pictures of wood top before covering with material only.Photo’s upside down (first attempt) Sorry!
John
Oscoda, Michigan
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Sat Feb 01, 2020 1:10 am
Original top framing. Overlaid with canvas, an unknown padding, and a diamond pattern
top fabric.
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Sat Feb 01, 2020 7:33 am
Thanks! Is that white canvas? Is the outside canvas or vinyl?
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Sat Feb 01, 2020 9:33 am
Here’s what I did with my top. Same general process.
https://www.mtfca.com/phpBB3/viewtopic.php?t=7960
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Sat Feb 01, 2020 9:46 am
Thanks Brad, that’s exactly what I needed. Did you leave the flannel showing for a headliner?
Jeepbone1
First Name: Brad
Last Name: Kirtner
Post by Jeepbone1 » Sat Feb 01, 2020 10:32 am
I sure did! I didn’t want to be looking at plain black/tan/white muslin. Too boring. The plaid material I found is stronger and more weather resistant anyway. Win-Win. I’m documenting the crap out of this build so keep a look out if there’s anything else I can help out with.
Brad
Gordon C
First Name: Gordon
Last Name: Clayton
* REQUIRED* Type and Year of Model Ts owned: 27 TT
Post by Gordon C » Sat Feb 01, 2020 1:14 pm
Have a 27 TT Closed cab with just a few badly weathered sticks too.
Just wondering if they used chicken wire on the wood to support the
padding like so many other 20's cars I had . I don't have enough left
of my top to check.
Gordon Clayton
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Feb 01, 2020 1:31 pm
No chicken wire roof foundation in model Ts or TTs.
Post by Allan » Sat Feb 01, 2020 5:07 pm
Here in Australia on our colonial built cars a layer of natural hessian/burlap was laid on the wooden slats. That is what is seen from underneath in the cabin. Next was a thin layer of felt. I use 1/4" dacron sheeting from a quilting supplies shop because it is not affected by moisture. Then the top material is applied, in many cases it was canvas.
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sat Feb 01, 2020 8:41 pm
It is a natural colored burlap sort of canvas, just like old feed sacks. It is faded
and weathered and has a few water stains. While I can't swear it is original to the
factory build, many, more knowing than me, have commented that it looks to be
"correct" OEM. Exterior is a vinyl-like material, similar to what was OEM for 50's
convertibles. Likely from being replaced at that time.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sat Feb 01, 2020 10:00 pm
Don,have you joined the Slow Turtle T club ?At least I won't be alone in the Tarheel T's :D
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Sun Feb 02, 2020 7:59 am
No Mack I don’t have a tt. I am finishing up one for a oil company. Their business was started in 24 with a tt delivering coal.
