24 tt closed cab top
Don ellis
Topic author - Posts: 390
- First Name: Don
- Last Name: Ellis
I am going to be putting a top wood and covering on a closed cab soon. The roof is mostly missing except a few sticks of wood. Does anyone have a plan or pictures of one complete? Both inside and out would be a great help. Thanks
Nunsio1
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Re: 24 tt closed cab top
I have a 24 C cab with a wood roof, tried kits but they didn’t fit, made it from scratch. Covered it with convertible top material. Have pictures of wood top before covering with material only.Photo’s upside down (first attempt) Sorry!
John
Oscoda, Michigan
John
Oscoda, Michigan
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Original top framing. Overlaid with canvas, an unknown padding, and a diamond pattern
top fabric.
top fabric.
Don ellis
- First Name: Don
- Last Name: Ellis
Thanks! Is that white canvas? Is the outside canvas or vinyl?
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Here’s what I did with my top. Same general process.
https://www.mtfca.com/phpBB3/viewtopic.php?t=7960
Don ellis
- First Name: Don
- Last Name: Ellis
Thanks Brad, that’s exactly what I needed. Did you leave the flannel showing for a headliner?
Jeepbone1
- First Name: Brad
I sure did! I didn’t want to be looking at plain black/tan/white muslin. Too boring. The plaid material I found is stronger and more weather resistant anyway. Win-Win. I’m documenting the crap out of this build so keep a look out if there’s anything else I can help out with.
Brad
Brad
Gordon C
- First Name: Gordon
- Last Name: Clayton
- * REQUIRED* Type and Year of Model Ts owned: 27 TT
Have a 27 TT Closed cab with just a few badly weathered sticks too.
Just wondering if they used chicken wire on the wood to support the
padding like so many other 20's cars I had . I don't have enough left
of my top to check.
Gordon Clayton
of my top to check.
Gordon Clayton
- Last Name: Humble
No chicken wire roof foundation in model Ts or TTs.
Here in Australia on our colonial built cars a layer of natural hessian/burlap was laid on the wooden slats. That is what is seen from underneath in the cabin. Next was a thin layer of felt. I use 1/4" dacron sheeting from a quilting supplies shop because it is not affected by moisture. Then the top material is applied, in many cases it was canvas.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
It is a natural colored burlap sort of canvas, just like old feed sacks. It is faded
and weathered and has a few water stains. While I can't swear it is original to the
factory build, many, more knowing than me, have commented that it looks to be
"correct" OEM. Exterior is a vinyl-like material, similar to what was OEM for 50's
convertibles. Likely from being replaced at that time.
tdump
- First Name: Mack
- Last Name: Cole
Don,have you joined the Slow Turtle T club ?At least I won't be alone in the Tarheel T's
Don ellis
- First Name: Don
- Last Name: Ellis
No Mack I don’t have a tt. I am finishing up one for a oil company. Their business was started in 24 with a tt delivering coal.
