Rebuilt generator
Topic author - Posts: 337
- First Name: Charles
- Last Name: Jenkins
- * REQUIRED* Type and Year of Model Ts owned: Coupe
Rebuilt generator
If you were going to buy a rebuilt generator who does the best job and where would you purchase it
- First Name: Andre
- Last Name: Valkenaers
Re: Rebuilt generator
Ron Patterson.
Andre
Belgium
Andre
Belgium
- First Name: Anthonie
- Last Name: Boer
Andre' Valkenaars Belgie
- First Name: Andre
And Toon Boer.
Toon teached me how to rebuild an armature
Ron teached me how it should be done to rebuild a generator and a starter.
Good luck
Andre
Belgium
Good luck
Andre
Belgium
- Last Name: Whelihan
- Board Member Since: 2008
Certainly there are some pretty reputable vendors mentioned that do a great job of rebuilding and setting up a generator. But if you want to stay more local, look around for a shop that does electrical work on old tractors. Many of these folks understand 3rd brush generators and can do a credible rebuild job on them. Set them up with John Regan's instructions once reinstalled.
I get gen and starter done by Buckeye, and they are in Ohio. Good work, good price. Pick ‘em up at Hershey.
https://www.buckeyeautoelectric.com/model-t-starters
- First Name: Andy
- Last Name: Loso
I rebuild them.
OSO Handy Restorations
alosoatq.com
alosoatq.com
Model T Ford Generator and Starter Rebuilding
I am no longer rebuilding Model T Ford generators and starters.
I am in the initial stages of transitioning the rebuilding business/process to the new owner.
Ron Patterson
Ron Patterson
- First Name: Mack
- Last Name: Cole
OH NO!
I was not far from trying to get in touch with you to rebuild 4 coils for my speedster.How much longer will you be doing coils?
I do not anticipate any changes to my Model T Ford ignition coil rebuilding activities.
In fact, I recently purchased enough parts to rebuild coils for the next ten years.
Then, after forty years of coil rebuilding I will probably stop.
Thinking positively.
Ron
Ron
- Last Name: Golden
Buckeye will sell you the parts and let you do it yourself, if you know what you are doing.
