Rebuilt generator
Charles J
First Name: Charles
Last Name: Jenkins
* REQUIRED* Type and Year of Model Ts owned: Coupe
Rebuilt generator
Post by Charles J » Wed May 13, 2020 11:24 pm
If you were going to buy a rebuilt generator who does the best job and where would you purchase it
AndreFordT
First Name: Andre
Last Name: Valkenaers
* REQUIRED* Type and Year of Model Ts owned: 1926 ; 1922 ; 1915.
Re: Rebuilt generator
Post by AndreFordT » Thu May 14, 2020 1:03 am
Ron Patterson.
Andre
Belgium
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Thu May 14, 2020 2:14 am
Andre' Valkenaars Belgie
AndreFordT
First Name: Andre
Post by AndreFordT » Thu May 14, 2020 3:06 am
And Toon Boer.
Toon teached me how to rebuild an armature
Ron teached me how it should be done to rebuild a generator and a starter.
Good luck
Andre
Belgium
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Thu May 14, 2020 7:54 am
Certainly there are some pretty reputable vendors mentioned that do a great job of rebuilding and setting up a generator. But if you want to stay more local, look around for a shop that does electrical work on old tractors. Many of these folks understand 3rd brush generators and can do a credible rebuild job on them. Set them up with John Regan's instructions once reinstalled.
Post by DanTreace » Thu May 14, 2020 8:04 am
I get gen and starter done by Buckeye, and they are in Ohio. Good work, good price. Pick ‘em up at Hershey.
https://www.buckeyeautoelectric.com/model-t-starters
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Thu May 14, 2020 8:24 am
I rebuild them.
OSO Handy Restorations
alosoatq.com
Ron Patterson
Model T Ford Generator and Starter Rebuilding
Post by Ron Patterson » Thu May 14, 2020 9:21 am
I am no longer rebuilding Model T Ford generators and starters.
I am in the initial stages of transitioning the rebuilding business/process to the new owner.
Ron Patterson
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu May 14, 2020 9:24 am
OH NO! :shock: I was not far from trying to get in touch with you to rebuild 4 coils for my speedster.How much longer will you be doing coils?
Ron Patterson
Post by Ron Patterson » Thu May 14, 2020 10:04 am
I do not anticipate any changes to my Model T Ford ignition coil rebuilding activities.
In fact, I recently purchased enough parts to rebuild coils for the next ten years.
Then, after forty years of coil rebuilding I will probably stop.
Thinking positively.
Ron
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu May 14, 2020 10:30 pm
Ok,thanks for the update!
J1MGolden
Last Name: Golden
Post by J1MGolden » Fri May 15, 2020 11:23 am
Buckeye will sell you the parts and let you do it yourself, if you know what you are doing.
