Tool For Cutting Hole in Dash For Speedometer
ModelTWoods
Topic author - Posts: 1597
- First Name: Terry
- Last Name: Woods
I asked this question several years ago and got several suggestions, but I didn't follow through and buy the tool at the time. Something about a tool used in cutting holes in radio cabinets, or something like that. I found them for sale on EBAY, but didn't save the information. What am I looking for?
Kevin Pharis
- Last Name: Pharis
Re: Tool For Cutting Hole in Dash For Speedometer
If you’re trying to be authentic...
Shane Lach
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
I bought a harbor freight hydraulic knock out punch set and it works like butter. not sure if it has the size you need but check it out.
Kevin, how can a can opener dated 1956 be authentic for any T model?
Kevin Pharis
- Last Name: Pharis
Sorry Allan... was the oldest one I could find a picture of...
You'll find a hole saw is the way, neater than a can opener
Here is an old time original, with bit and brace to cut....work out.
I have one like this that was my Dad's from the 50's. Works great and has all its cutters too for different diameters.
Or get a single size cutter for your speedometer o.d.
Using a hole saw for the size you need will work fine or a Greenlee hole punch will work also.
It’s a metal dash and the 2 items mentioned above are used for cutting holes in metal doors, electrical panels, boxes and etc.
if you have a Grainger industrial supply close to you they have everything you need. They also have an online catalog you can check out. I worked as a maintenance mechanic before I retired and used both in all kinds of metal panels and etc.
They will definitely work.
Kevin Pharis
- Last Name: Pharis
I stand corrected... turns out the P-38 can opener wasn’t invented till 1942. So NOT a period correct holemaking method. Guess you’re goin to have to look for an ‘ol bit and brace... or get out the ‘ol trusty cold chisel!!
BobD
- First Name: Bob
- Last Name: Doris
Lacking the proper sized hole saw, I used this Adjustable Circle Cutter I had on hand.
tgreifhahn
- First Name: Tom
- Last Name: Greifhahn
- * REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Try a tool rental store. They usually have quality specialty tools for rent at affordable rates.
Tmodelt
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
The P38 key is a great invention. I retired from the commercial nuclear industry and carried one on my work key ring. A very useful tool. Wish that I still had mine. I "willed" it to a newbie when I left. I haven't replaced it yet.
Kim R. Wynn
Kim R. Wynn
