Tool For Cutting Hole in Dash For Speedometer
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Jul 02, 2020 5:19 pm
I asked this question several years ago and got several suggestions, but I didn't follow through and buy the tool at the time. Something about a tool used in cutting holes in radio cabinets, or something like that. I found them for sale on EBAY, but didn't save the information. What am I looking for?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Tool For Cutting Hole in Dash For Speedometer
Post by Kevin Pharis » Thu Jul 02, 2020 5:27 pm
If you’re trying to be authentic...
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Thu Jul 02, 2020 5:35 pm
Greenlee punch springs instantly to mind.
http://www.mtfca.com/discus/messages/50 ... 1438184121
Shane Lach
First Name: Shane
Last Name: Lach
Post by Shane Lach » Thu Jul 02, 2020 5:40 pm
I bought a harbor freight hydraulic knock out punch set and it works like butter. not sure if it has the size you need but check it out.
Post by Allan » Thu Jul 02, 2020 7:56 pm
Kevin, how can a can opener dated 1956 be authentic for any T model? :D
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Jul 02, 2020 8:44 pm
Sorry Allan... was the oldest one I could find a picture of...😔
Post by DanTreace » Thu Jul 02, 2020 9:06 pm
You'll find a hole saw is the way, neater than a can opener ;)
Here is an old time original, with bit and brace to cut....work out.
I have one like this that was my Dad's from the 50's. Works great and has all its cutters too for different diameters.
Or get a single size cutter for your speedometer o.d.
Post by John kuehn » Thu Jul 02, 2020 9:49 pm
Using a hole saw for the size you need will work fine or a Greenlee hole punch will work also.
It’s a metal dash and the 2 items mentioned above are used for cutting holes in metal doors, electrical panels, boxes and etc.
if you have a Grainger industrial supply close to you they have everything you need. They also have an online catalog you can check out. I worked as a maintenance mechanic before I retired and used both in all kinds of metal panels and etc.
They will definitely work.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Jul 02, 2020 11:35 pm
I stand corrected... turns out the P-38 can opener wasn’t invented till 1942. So NOT a period correct holemaking method. Guess you’re goin to have to look for an ‘ol bit and brace... or get out the ‘ol trusty cold chisel!! :twisted: :lol:
BobD
First Name: Bob
Last Name: Doris
Post by BobD » Fri Jul 03, 2020 1:08 am
Lacking the proper sized hole saw, I used this Adjustable Circle Cutter I had on hand.
tgreifhahn
Last Name: Greifhahn
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Post by tgreifhahn » Fri Jul 03, 2020 1:15 pm
Try a tool rental store. They usually have quality specialty tools for rent at affordable rates.
Tmodelt
First Name: Kim
Last Name: Wynn
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Post by Tmodelt » Sat Jul 04, 2020 11:50 am
The P38 key is a great invention. I retired from the commercial nuclear industry and carried one on my work key ring. A very useful tool. Wish that I still had mine. I "willed" it to a newbie when I left. I haven't replaced it yet.
Kim R. Wynn
