Trans cover
Mel King
First Name: Melvin
Last Name: King
Trans cover
Post by Mel King » Mon Jul 06, 2020 6:17 pm
Is 13-15 trans cover the same but the pedals? MEL
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Trans cover
Post by R.V.Anderson » Mon Jul 06, 2020 6:50 pm
Essentially yes, but the earliest '13 covers had a different clutch shaft to which the yokes were keyed and bolted. Later ones were pinned to the shaft and riveted over.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: Trans cover
Post by Jeepbone1 » Mon Jul 06, 2020 11:08 pm
RV, is this one like you’re talking about?
Brad
modeltbarn
First Name: Gary
Last Name: London
Re: Trans cover
Post by modeltbarn » Mon Jul 06, 2020 11:48 pm
Also in 15 the reinforcing ribs appeared near the bolt holes.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Trans cover
Post by R.V.Anderson » Tue Jul 07, 2020 2:02 pm
Yes, that's the shaft. Actually, according to Ford, the ribs first appeared in some 1912 covers but it wasn't until late 1913 that they all had them.
Re: Trans cover
Post by Allan » Wed Jul 08, 2020 3:04 am
My Sept, 12 assembled B series motor has the reinforcements at the trans cover bolt holes. Somewhere in my reading a photo of an alloy trans cover with a hand engraved 1912 casting date, showed the reinforcing ribs, so they did start early on.
