Trans cover
Topic author - Posts: 96
- First Name: Melvin
- Last Name: King
Trans cover
Is 13-15 trans cover the same but the pedals? MEL
- First Name: R.V.
- Last Name: Anderson
Re: Trans cover
Essentially yes, but the earliest '13 covers had a different clutch shaft to which the yokes were keyed and bolted. Later ones were pinned to the shaft and riveted over.
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: Trans cover
RV, is this one like you’re talking about?R.V.Anderson wrote: ↑Mon Jul 06, 2020 6:50 pmEssentially yes, but the earliest '13 covers had a different clutch shaft to which the yokes were keyed and bolted. Later ones were pinned to the shaft and riveted over.
Brad
- First Name: Gary
- Last Name: London
Re: Trans cover
Also in 15 the reinforcing ribs appeared near the bolt holes.
- First Name: R.V.
Re: Trans cover
Yes, that's the shaft. Actually, according to Ford, the ribs first appeared in some 1912 covers but it wasn't until late 1913 that they all had them.
Re: Trans cover
My Sept, 12 assembled B series motor has the reinforcements at the trans cover bolt holes. Somewhere in my reading a photo of an alloy trans cover with a hand engraved 1912 casting date, showed the reinforcing ribs, so they did start early on.
