09-10
Post by Dollisdad » Tue Aug 11, 2020 12:32 pm
Re: 09-10
Post by Rich Eagle » Tue Aug 11, 2020 1:45 pm
The third photo with the girl and baby would make a delightful painting.
Maybe some day.
You find the best pictures.
Re: 09-10
Post by Dollisdad » Tue Aug 11, 2020 4:01 pm
David N
First Name: David
Last Name: Nebelsky
Re: 09-10
Post by David N » Tue Aug 11, 2020 5:19 pm
Second photo from the top looks like a 2 lever, 2 pedal car.
Alex Dragone
First Name: Alex
Last Name: Dragone
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Re: 09-10
Post by Alex Dragone » Wed Aug 12, 2020 9:22 pm
Notice also on the car in the second photo that not only is it a 2 lever but it has Atwood Castle three tier side lamps and Atwood Castle tail lamp and most interestingly it has the two bolt front body mount and a two bolt body mount for the center body mount which I have not seen before. Usually the very early cars had 4 bolts in that position and later the usual three, but not 2.
Alex Dragone
First Name: Alex
Last Name: Dragone
Re: 09-10
Post by Alex Dragone » Wed Aug 12, 2020 9:27 pm
Also if you look closely in the reflection of the body near the rear fender you can see there are only two rivets for each fender bracket on the rear fender instead of the usual 4. Very odd car, maybe the very first model T?
Alex Dragone
First Name: Alex
Last Name: Dragone
Re: 09-10
Post by Alex Dragone » Wed Aug 12, 2020 9:29 pm
Sorry for another separate post but that car also has super short front fenders. Very interesting
Drkbp
First Name: Kenneth
Last Name: Parker
Re: 09-10
Post by Drkbp » Thu Aug 13, 2020 11:55 am
The second photo above is very much like the early car I'll post below.
Other than being very dirty and the top not being on the car, seems very much the same.
Two pedal, 2 bolt mounts, lamps and all.
Also, seems the building in the background of both photos may be the Piquette Avenue Plant.
