09-10
Re: 09-10
The third photo with the girl and baby would make a delightful painting.
Maybe some day.
You find the best pictures.
Maybe some day.
Alex Dragone
- First Name: Alex
- Last Name: Dragone
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Re: 09-10
Notice also on the car in the second photo that not only is it a 2 lever but it has Atwood Castle three tier side lamps and Atwood Castle tail lamp and most interestingly it has the two bolt front body mount and a two bolt body mount for the center body mount which I have not seen before. Usually the very early cars had 4 bolts in that position and later the usual three, but not 2.
Alex Dragone
- First Name: Alex
Re: 09-10
Also if you look closely in the reflection of the body near the rear fender you can see there are only two rivets for each fender bracket on the rear fender instead of the usual 4. Very odd car, maybe the very first model T?
Alex Dragone
- First Name: Alex
Re: 09-10
Sorry for another separate post but that car also has super short front fenders. Very interesting
Drkbp
- First Name: Kenneth
- Last Name: Parker
Re: 09-10
The second photo above is very much like the early car I'll post below.
Other than being very dirty and the top not being on the car, seems very much the same.
Two pedal, 2 bolt mounts, lamps and all.
Also, seems the building in the background of both photos may be the Piquette Avenue Plant.
